I have the following output script that gets run when I build my code (the script just does a couple of things like copying the binaries into a more friendly directory and renaming it).
However, I don’t want this to happen to run if I’m unit testing. I have used print(env.Dump()) to try and see if there’s anything that identifies it as a unit test but it doesn’t seem to work.
