Hi folks. When writing the project decided to divide it into files, when adding all the logic that relates to the sensor BME280 on the files, the code stopped compiling. Here is the error text:collect2.exe: error: ld returned 1 exit status *** [.pio\build\upesy_wroom\firmware.elf] Error 1
If all the logic is located in one file, the code compiles and works fine.
Here’s the code by file: main.cpp
#include "bme280.h"
TaskHandle_t Task1Handle;
void Task1code(void *pvParameters);
void setup()
Serial.begin(9600);
I2CBME.begin(I2C_SDA, I2C_SCL, 100000);
bool status;
/// default settings
// (you can also pass in a Wire library object like &Wire2)
status = bme.begin(0x76, &I2CBME);
if (!status)
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
Serial.println("-- Default Test --");
xTaskCreatePinnedToCore(
Task1code, /* Функція для реалізації задачі*/
"Task1", /* Назва задачі */
1500, /* Розмір стеку */
NULL, /* Параметр задачі */
2, /* Пріорітет задачі */
&Task1Handle,/* Покажчик на задачу */
0); /* Закріплення задачі за ядром */
String TempHumidityPressure;
for(;;)
TempHumidityPressure = BME280();
Serial.println(TempHumidityPressure);
vTaskDelay(2000 / portTICK_PERIOD_MS);
void loop() {}
bme280.h
#ifndef BME280_H_
#define BME280_H_
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define I2C_SDA 17
#define I2C_SCL 5
TwoWire &I2CBME = Wire;
Adafruit_BME280 bme;
String BME280();
bme280.cpp
#include "bme280.h"
String BME280()
float temperature, humidity, pressure;
temperature = bme.readTemperature();
humidity = bme.readHumidity();
pressure = bme.readPressure() / 100.0F; // Преобразуем давление в hPa
// Создаем строку с результатами
TempHumidityPressure = "Temperature:" + String(temperature) + " C, " +
"Humidity:" + String(humidity) + " %, " +
"Pressure:" + String(pressure) + " hPa";
return TempHumidityPressure;
platformio.ini
[env:upesy_wroom]
board = upesy_wroom
monitor_speed = 9600
adafruit/Adafruit BME280 Library@^2.2.4
adafruit/Adafruit Unified Sensor@^1.1.14
Any idea why the code stopped compiling when I split it into different files? Thank you very much for your time!
