Hello Max.
Great. I’ve got a big improvement with your information. Now it looks like it tries to start.
Now it shows some errors. First I thought there could be some conflict with the FTP server:
#include <ESP32FTPServer.h> // henrikste/ESP32FTPServer@^0.0.2
String FTP_user = “usr”;
String FTP_psw = “psw”;
FtpServer servidorFTP;
servidorFTP.begin(FTP_user, FTP_psw);
mDashBegin(DEVICE_PASSWORD);
Doing so, I get this:
/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/tasks.c:4826 (xTaskNotify)- assert failed!
abort() was called at PC 0x4008d104 on core 1
ELF file SHA256: 0000000000000000
Backtrace: 0x40089b78:0x3ffb1f00 0x40089df5:0x3ffb1f20 0x4008d104:0x3ffb1f40 0x400d33f2:0x3ffb1f60 0x400e33b6:0x3ffb1fb0 0x4008ae06:0x3ffb1fd0
#0 0x40089b78:0x3ffb1f00 in invoke_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/panic.c:715
#1 0x40089df5:0x3ffb1f20 in abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/panic.c:715
#2 0x4008d104:0x3ffb1f40 in xTaskNotify at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/tasks.c:4999
#3 0x400d33f2:0x3ffb1f60 in setup() at src/main.cpp:1408
#4 0x400e33b6:0x3ffb1fb0 in loopTask(void*) at /Users/cirobruno/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:18
#5 0x4008ae06:0x3ffb1fd0 in vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c:355 (discriminator 1)
Rebooting…
ets Jun 8 2016 00:22:57
Placing mDashBegin(DEVICE_PASSWORD);
as the last instruction in void setup()
, I get this:
2021-10-26 21:12:10 E dns.c:124:dns_cb stray DNS reply
2021-10-26 21:12:11 E event.c:18:mg_error 0x3d setup err 0x7f00
2021-10-26 21:12:11 E dns.c:124:dns_cb stray DNS reply
2021-10-26 21:12:12 E event.c:18:mg_error 0x3f setup err 0x7f00
2021-10-26 21:12:12 E dns.c:124:dns_cb stray DNS reply
2021-10-26 21:12:13 E event.c:18:mg_error 0x38 setup err 0x7f00
2021-10-26 21:12:14 E event.c:18:mg_error 0x3b setup err 0x7f00
2021-10-26 21:12:15 E event.c:18:mg_error 0x3a parse(/spiffs/ca.pem) err 0x3f80
2021-10-26 21:12:16 E event.c:18:mg_error 0x3c parse(/spiffs/ca.pem) err 0x3f80
2021-10-26 21:12:17 E event.c:18:mg_error 0x3d parse(/spiffs/ca.pem) err 0x3f80
2021-10-26 21:12:18 E event.c:18:mg_error 0x3f parse(/spiffs/ca.pem) err 0x3f80
2021-10-26 21:12:19 E event.c:18:mg_error 0x38 parse(/spiffs/ca.pem) err 0x3f80
but the device isn’t reboot.
Commenting out servidorFTP.begin(FTP_user, FTP_psw);
, the behavior is the same.
SPI drive has an empty partition as big as the code’s itself:
# Name, Type, SubType, Offset, Size, Flags
nvs,data,nvs,0x9000,0x4000,
otadata,data,ota,0xD000,0x2000,
phy_init,data,phy,0xF000,0x1000,
app0,app,ota_0,0x10000,0x120000,
app1,app,ota_1,0x130000,0x120000,
spiffs,data,spiffs,0x250000,0x1B0000,
and mDash doesn’t connect at all:
Btw, should I fill something else in mDash device’s configuration? Or does it fills automatically when the device connects?
Thank you.
Regards, Ciro
