I’ve made an update on my docker Alpine, and my environment is not broken. Platformio is unable to find gcc for stm32 anymore.
GCC seems to be correctly installed as the command “docker container exec qapi_web_1 find / -name arm-none-eabi-gcc” returns “/root/.platformio/packages/toolchain-gccarmnoneeabi/bin/arm-none-eabi-gcc”.
Here is the log of my pio run command :
docker container exec qapi_web_1 platformio run -d /project/NUCLEO-F072RB/
Processing nucleo_f072rb (platform: ststm32; board: nucleo_f072rb; framework: stm32cube)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_f072rb.html
PLATFORM: ST STM32 (15.4.1) > ST Nucleo F072RB
HARDWARE: STM32F072RBT6 48MHz, 16KB RAM, 128KB Flash
- framework-stm32cubef0 @ 1.11.3
- tool-ldscripts-ststm32 @ 0.2.0
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
LDF Modes: Finder ~ off, Compatibility ~ soft
Gate build configuration:
* TinyJSON translation format selected.
Pipe build configuration:
* SERIAL mode selected.
* NUCLEO-F0 HAL selected.
Luos engine build configuration:
/usr/local/bin/python -m pip install pyluos --upgrade --quiet
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
* Pyluos revision 2.2.8 ready.
* STM32F0 HAL selected for Luos and Robus.
* Telemetry enabled.
Found 26 compatible libraries
|-- luos_engine @ 2.7.0+sha.024a688
|-- led @ 0.7.0
|-- Blinker_App @ 1.0.0
|-- Pipe @ 1.3.0
|-- Gate @ 1.5.0
|-- Inspector @ 1.4.0
Compiling .pio/build/nucleo_f072rb/FrameworkHALDriver/Src/stm32f0xx_hal.o
Compiling .pio/build/nucleo_f072rb/FrameworkHALDriver/Src/stm32f0xx_hal_adc.o
sh: arm-none-eabi-gcc: not found
Compiling .pio/build/nucleo_f072rb/FrameworkHALDriver/Src/stm32f0xx_hal_adc_ex.o
*** [.pio/build/nucleo_f072rb/FrameworkHALDriver/Src/stm32f0xx_hal.o] Error 127
*** [.pio/build/nucleo_f072rb/FrameworkHALDriver/Src/stm32f0xx_hal_adc.o] Error 127
*** [.pio/build/nucleo_f072rb/FrameworkHALDriver/Src/stm32f0xx_hal_adc_ex.o] Error 127
Compiling .pio/build/nucleo_f072rb/FrameworkHALDriver/Src/stm32f0xx_hal_can.o
*** [.pio/build/nucleo_f072rb/FrameworkHALDriver/Src/stm32f0xx_hal_can.o] Error 127
========================== [FAILED] Took 6.75 seconds ==========================
Do you have any ideas ?
