I have picked up my project after about 2 months of downtime and unable to compile it after updating everything.
The key error messages:
.pio/libdeps/d1_mini_pro/ESPAsyncWiFiManager/ESPAsyncWiFiManager.cpp: In member function 'boolean AsyncWiFiManager::startConfigPortal(const char*, const char*)':
.pio/libdeps/d1_mini_pro/ESPAsyncWiFiManager/ESPAsyncWiFiManager.cpp:551:24: error: use of deleted function 'DNSServer& DNSServer::operator=(const DNSServer&)'
551 | *dnsServer=DNSServer();
In file included from .pio/libdeps/d1_mini_pro/ESPAsyncWiFiManager/ESPAsyncWiFiManager.h:31,
from .pio/libdeps/d1_mini_pro/ESPAsyncWiFiManager/ESPAsyncWiFiManager.cpp:14:
/Users/zmarkella/.platformio/packages/framework-arduinoespressif8266/libraries/DNSServer/src/DNSServer.h:67:7: note: 'DNSServer& DNSServer::operator=(const DNSServer&)' is implicitly deleted because the default definition would be ill-formed:
67 | class DNSServer
/Users/zmarkella/.platformio/packages/framework-arduinoespressif8266/libraries/DNSServer/src/DNSServer.h:67:7: error: use of deleted function 'std::unique_ptr<_Tp [], _Dp>& std::unique_ptr<_Tp [], _Dp>::operator=(const std::unique_ptr<_Tp [], _Dp>&) [with _Tp = DNSS_REQUESTER; _Dp = std::default_delete<DNSS_REQUESTER []>]'
In file included from /Users/zmarkella/.platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/10.3.0/memory:83,
from /Users/zmarkella/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.h:32,
from /Users/zmarkella/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.h:28,
from /Users/zmarkella/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:34,
from .pio/libdeps/d1_mini_pro/ESPAsyncWiFiManager/ESPAsyncWiFiManager.h:18,
/Users/zmarkella/.platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/10.3.0/bits/unique_ptr.h:724:19: note: declared here
724 | unique_ptr& operator=(const unique_ptr&) = delete;
Why do I have an issue with a built-in DNSServer library? Has something changed and should some other parts of the code be updated?
The installed packages:
pio pkg list
Resolving d1_mini_pro dependencies...
Platform espressif8266 @ 4.2.0 (required: espressif8266)
├── framework-arduinoespressif8266 @ 3.30102.0 (required: platformio/framework-arduinoespressif8266 @ ~3.30102.0)
├── tool-esptool @ 1.413.0 (required: platformio/tool-esptool @ <2)
├── tool-esptoolpy @ 1.30000.201119 (required: platformio/tool-esptoolpy @ ~1.30000.0)
└── toolchain-xtensa @ 2.100300.220621 (required: platformio/toolchain-xtensa @ ~2.100300.0)
Libraries
├── Adafruit NeoPixel @ 1.11.0 (required: adafruit/Adafruit NeoPixel @ ^1.6.0)
├── ArduinoJson @ 6.21.2 (required: bblanchon/ArduinoJson @ ^6.20.1)
├── ESP Async WebServer @ 1.2.3 (required: me-no-dev/ESP Async WebServer @ ^1.2.3)
│ └── ESPAsyncTCP @ 1.2.2 (required: ESPAsyncTCP)
├── ESPAsyncWiFiManager @ 0.23.0 (required: alanswx/ESPAsyncWiFiManager @ ^0.23)
├── PubSubClient @ 2.8.0 (required: knolleary/PubSubClient @ ^2.8)
├── RFM69 @ 1.5.2 (required: lowpowerlab/RFM69 @ ^1.4.1)
│ └── SPIFlash @ 101.1.3 (required: SPIFlash)
└── Uptime Library @ 1.0.0 (required: yiannisbourkelis/Uptime Library @ ^1.0.0)
