Hi all!
I want to compile the code for this DIY Signal-Generator:
When I execute „PIO Debug“ in VS Code I get this message:
I already tried to add this in platformio.ini but this won‘t fix the error:
lib_deps = ´https://github.com/PaulStoffregen/OneWire.git´
Thanks for your help!
Well given the age of the project, it is highly likely the platform version (“espressif32” and with it the use Arduino-ESP32 core version) and libraries (like TFT_eSPI) have long gone out of sync – with the platformio.ini having platform = espressif32, it’s instructing it to use the latest available espressif32 Platform (which contains Arduino-ESP32 2.0.11 atm), while three years ago, that one was likely much older (maybe Arduino-ESP32 1.0.6).
So to counteract that, you should write
platform = espressif32@3.5.0
in the platformio.ini, since per release notes and dates, that matches it more closely.
It worked! Compiled successfully.
Thanks a lot!
