Disable the legacy auto-crawler for a library without publishing a version?
Two of my libraries, sebajost/BlaeckSerial and sebajost/BlaeckTCP, were
registered in 2020 and appear to still be on the legacy auto-crawler. Versions get
published to the registry whenever I change the version field in
library.properties — no tag, no pio pkg publish, and no publishing workflow in
either repository.
Seven versions arrived this way, each on the day its version bump was committed:
BlaeckSerial 5.0.2 2026-03-31
6.0.2 2026-07-01
7.0.0 2026-08-08
BlaeckTCP 5.0.3 2026-03-31
6.0.2 2026-07-14
6.1.0 2026-08-06
7.0.0 2026-08-07
None of them has a git tag. Arduino’s Library Manager, which publishes from tags,
is still on 6.0.1 for both as a result. I had not installed PlatformIO Core at all
until yesterday, so none of these were published by me.
The practical problem is that the version field acts as a publish trigger. I bumped
both to 7.0.0 early in a development cycle and kept working, so the 7.0.0 that users
can install today is a mid-development snapshot rather than a release. I have a few
months of work ahead on both and would like to stop that happening again.
Two questions:
  1. maxgerhardt mentioned in an older thread that the crawler versus manual
    publishing is "a setting per-libanged for these two
    libraries on request, without publishing a version? I would rather not spend a
    version number on each purely to
  2. Is ivankravets’ statement in that publishing one
    version manually disables auto-crawling permanently? It is from 2021, so I would
    like to confirm before relying o
    https://community.platformio.orgished-with-old-platformio-registry-method/18855/8
Unrelated and minor: the registry links release notes to
https://github.com/sebaJoSt/Blaeckwhich 404s. My tags have no vprefix, so the working URL is…/releases/tag/6.0.1. It looks like the link is built by prepending v`pository’s tags.
The same applies to BlaeckTCP.
Thanks.
Maxbe u can just delete both libaries and disable the autocrawler, so I can release later the right versions.
The legacy crawler appears to be publishing these versions automatically. Changing library.properties seems sufficient to trigger publishing.
yes, but how to disable the autocrawler? this behavior leads to prereleases being published to platformio
CC @ivankravets for library management
The autocrawler was disabled for your libraries. Once a new release is ready, please publish them manually using pio pkg publish path/to/library/folder. For more information, see the pio pkg publish — PlatformIO latest documentation
