I’m working on a project that has the following directory structure:
lib/
+-- ModuleX/
| +-- ModuleX_Agent.c
| +-- ModuleX_Agent.h
| +-- ModuleX_Errors.h
| +-- ModuleX_Stub.c
| +-- ModuleX_Stub.h
+-- ModuleY/
+-- ModuleY_Agent.c
+-- ModuleY_Agent.h
+-- ModuleY_Errors.h
+-- ModuleY_Stub.c
+-- ModuleY_Stub.h
src/
+-- MyMain.c
The MyMain.c
file includes both ModuleX_Agent.h
and ModuleY_Agent.h
. The Agents
include the respective Stubs
and Errors
. However, I’m encountering two issues:
This one is not critical but when I had the files structured as
lib/
+-- ModuleX_Agent/
| +-- ModuleX_Agent.c
| +-- ModuleX_Agent.h
+-- ModuleX_Errors/
+-- ModuleX_Stub/
| +-- ModuleX_Stub.c
| +-- ModuleX_Stub.h
+-- ModuleY_Agent/
| +-- ModuleY_Agent.c
| +-- ModuleY_Agent.h
+-- ModuleY_Errors/
+-- ModuleY_Stub/
+-- ModuleY_Stub.c
+-- ModuleY_Stub.h
src/
+-- MyMain.c
I could include my libraries as #include <WhateverLibrary.h>
, now I can only include them like #include "WhateverLibrary.h"
I also can’t seem to include the Agents
in MyMain.c
file.
I’m still struggling to understand the correct file/directory structure that I should follow. Can anyone help me understand how I should organize my files?
The folder structure looks correct per readme. If the library dependency finder can’t find a certain lib, there might be conditional includes at play in the code and you might need a different lib_ldf_mode
. Does adding lib_ldf_mode = deep+
to the platformio.ini
make a difference in compilation?
It might also be the case the Intellisense tricks you and it builds fine. IntelliSense in VSCode is not rebuilt until a build is made (or an explicit Ctrl+Shift+P → Rebuild IntellISense is done).
If that still does not fix the problem, please upload the exact project folder you’re having problems with for inspection.
So, some feedback regarding your answer:
First of all, thank you, I’ll accept it as a solution.
Second, I’ve cleaned and built the project with and without adding lib_ldf_mode = deep+
file. They both produced the same result. It compiles without warnings but the “problems” tab still “informs” this:
#include errors detected. Please update your includePath. (...)
cannot open source file "ModuleX_Agent.h
(I’m trying with just one module)
Is this a case of Intellisense tricking me? Is there a way to indicate to Intellisense this is not a problem?
I’ve tinkered with the includePath. Intellisense works fine now, thank you @maxgerhardt !
Manually? That is almost never good because the .vscode/c_cpp_properties.json
(aka, the IntelliSense configuration) is automatically regenerated on build. Does a Intellisense rebuild not work in this case?
If it builds but VSCode complains “File not found :(”, IntelliSense is tricking you.
Yes, manually. I read that warning before changing the file but I don’t know how to rebuild Intellisense (all I can find online mentions restarting VSCode but that doesn’t work) and this seems to do the trick. What should I do to rebuild Intellisense “the right way”?
It’s a PlatformIO provided command in the command palette.
Thank you, I owe you one
I always felt like this forum is much warmer and nicer to people than stackoverflow and I’m glad I had the chance to verify that myself.
