Different error types- can't use a variable, no such member, expression can't be used
This is the script:
  Rui Santos
  Complete project details at https://randomnerdtutorials.com
// Import required libraries
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
#include <Adafruit_Sensor.h>
#include <DHT.h>
// Replace with your network credentials
const char *ssid = "ssid";
const char *password = "password";
#define DHTPIN 27 // Digital pin connected to the DHT sensor
// Uncomment the type of sensor in use:
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE    DHT22     // DHT 22 (AM2302)
//#define DHTTYPE    DHT21     // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readDHTTemperature()
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  //float t = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(t))
    Serial.println("Failed to read from DHT sensor!");
    return "--";
  else
    Serial.println(t);
    return String(t);
String readDHTHumidity()
  float h = dht.readHumidity();
  if (isnan(h))
    return "--";
  else
    Serial.println(h);
    return String(h);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
  <style>
    html {
     font-family: Arial;
     display: inline-block;
     margin: 0px auto;
     text-align: center;
    h2 { font-size: 3.0rem; }
    p { font-size: 3.0rem; }
    .units { font-size: 1.2rem; }
    .dht-labels{
      font-size: 1.5rem;
      vertical-align:middle;
      padding-bottom: 15px;
  </style>
</head>
<body>
  <h2>ESP32 DHT Server</h2>
  <p>
    <i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
    <span class="dht-labels">Temperature</span>
    <span id="temperature">%TEMPERATURE%</span>
    <sup class="units">&deg;C</sup>
  </p>
  <p>
    <i class="fas fa-tint" style="color:#00add6;"></i>
    <span class="dht-labels">Humidity</span>
    <span id="humidity">%HUMIDITY%</span>
    <sup class="units">%</sup>
  </p>
</body>
<script>
setInterval(function ( ) {
  var xhttp = new XMLHttpRequest();
  xhttp.onreadystatechange = function() {
    if (this.readyState == 4 && this.status == 200) {
      document.getElementById("temperature").innerHTML = this.responseText;
  xhttp.open("GET", "/temperature", true);
  xhttp.send();
}, 10000 ) ;
      document.getElementById("humidity").innerHTML = this.responseText;
  xhttp.open("GET", "/humidity", true);
  xhttp.send();
}, 10000 ) ;
</script>
</html>)rawliteral";
// Replaces placeholder with DHT values
String processor(const String &var)
  //Serial.println(var);
  if (var == "TEMPERATURE")
    return readDHTTemperature();
  else if (var == "HUMIDITY")
    return readDHTHumidity();
  return String();
void setup()
  // Serial port for debugging purposes
  dht.begin();
  // Connect to Wi-Fi
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    delay(1000);
    Serial.println("Connecting to WiFi..");
  // Print ESP32 Local IP Address
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
    request->send_P(200, "text/html", index_html, processor);
  server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request) {
    request->send_P(200, "text/plain", readDHTTemperature().c_str());
  server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request) {
    request->send_P(200, "text/plain", readDHTHumidity().c_str());
  // Start server
  server.begin();
void loop()
These are the errors:
The terminal process "C:\Users\joema\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
> Executing task in folder Web_Server_DHT11_WeMos: C:\Users\joema\.platformio\penv\Scripts\platformio.exe run <
Processing wemos_d1_mini32 (platform: espressif32; board: wemos_d1_mini32; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/wemos_d1_mini32.html
PLATFORM: Espressif 32 1.12.4 > WeMos D1 MINI ESP32
Found 48 compatible libraries
|-- <ESP Async WebServer> 1.2.3
|   |-- <AsyncTCP> 1.1.1
|   |-- <FS> 1.0
|   |-- <WiFi> 1.0
|-- <WiFi> 1.0
|-- <Adafruit Unified Sensor> 1.1.4
|-- <DHT> 1.2.1
|   |-- <Ticker> 1.1
Compiling .pio\build\wemos_d1_mini32\src\main.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib282\ESP Async WebServer\SPIFFSEditor.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib282\ESP Async WebServer\WebAuthentication.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib282\ESP Async WebServer\WebHandlers.cpp.o
src\main.cpp:25:24: error: expected primary-expression before ')' token
src\main.cpp:25:5: error: cannot declare variable 'dht' to be of abstract type 'DHT'
In file included from C:/Users/joema/.platformio/lib/DHT/src/DHT.h:28:0,
                 from src\main.cpp:12:
C:/Users/joema/.platformio/lib/DHT/src/DHT.hpp:36:7: note:   because the following virtual functions are pure within 'DHT':
 class DHT {
C:/Users/joema/.platformio/lib/DHT/src/DHT.hpp:43:17: note:     virtual float DHT::getTemperature()
   virtual float getTemperature() = 0;
C:/Users/joema/.platformio/lib/DHT/src/DHT.hpp:44:17: note:     virtual float DHT::getHumidity()
   virtual float getHumidity() = 0;
src\main.cpp: In function 'String readDHTTemperature()':
src\main.cpp:34:33: error: expression cannot be used as a function
src\main.cpp: In function 'String readDHTHumidity()':
src\main.cpp:53:30: error: expression cannot be used as a function
src\main.cpp: In function 'void setup()':
src\main.cpp:148:7: error: 'class DHT' has no member named 'begin'
   dht.begin();
Compiling .pio\build\wemos_d1_mini32\lib282\ESP Async WebServer\WebRequest.cpp.o
*** [.pio\build\wemos_d1_mini32\src\main.cpp.o] Error 1
================================================= [FAILED] Took 10.70 seconds =================================================
|   |-- <AsyncTCP> 1.1.1
|   |-- <FS> 1.0
|   |-- <WiFi> 1.0
|-- <WiFi> 1.0
|-- <DHT> 1.2.1
|   |-- <Ticker> 1.1
Compiling .pio\build\wemos_d1_mini32\lib282\ESP Async WebServer\WebResponses.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib282\ESP Async WebServer\WebServer.cpp.o
Compiling .pio\build\wemos_d1_mini32\libe0a\Adafruit Unified Sensor\Adafruit_Sensor.cpp.o
 class DHT {
   dht.begin();
Archiving .pio\build\wemos_d1_mini32\libe0a\libAdafruit Unified Sensor.a
Compiling .pio\build\wemos_d1_mini32\lib8c6\Ticker\Ticker.cpp.o
Archiving .pio\build\wemos_d1_mini32\lib8c6\libTicker.a
Compiling .pio\build\wemos_d1_mini32\lib068\DHT\DHT.cpp.o
This is the library I edited to add a few class members:
Copyright 2018 Bert Melis
Permission is hereby granted, free of charge, to any person obtaining a
copy of this software and associated documentation files (the
"Software"), to deal in the Software without restriction, including
without limitation the rights to use, copy, modify, merge, publish,
distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to
the following conditions:
The above copyright notice and this permission notice shall be included
in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#pragma once
#include <functional>
#include <Ticker.h>
#include <FunctionalInterrupt.h>
typedef std::function<void(int8_t)> Callback;
class DHT {
 public:
  DHT();
  void setPin(uint8_t pin);
  void setCallback(Callback cb);
  void read();
  const int8_t ready() const;
  const char* getError();
float readTemperature;
float readHumidity;
 protected:
  volatile int8_t _result;
  volatile uint8_t _data[5];
 private:
  uint8_t _pin;
  Callback _callback;
  Ticker _timer;
  char _errorStr[5];
  volatile uint8_t _counter;
  volatile uint32_t _previousMicros;
  static void ICACHE_RAM_ATTR _handleRead(DHT* instance);
  void ICACHE_RAM_ATTR _handleAck();
  void ICACHE_RAM_ATTR _handleData();
  static void ICACHE_RAM_ATTR _timeout(DHT* instance);
  void ICACHE_RAM_ATTR _tryCallback();
class DHT11 : public DHT {
 public:
  DHT11();
  float getTemperature();
  float getHumidity();
class DHT22 : public DHT {
 public:
  DHT22();
(I added the two floats at the end to get these class members declared.)
The DHT class contains a couple of virtual member functions:
This means that the DHT class is abstract and cannot be used to declare a variable. So this is wrong:
DHT dht(...);
To use an abstract class requires you to create a new class, which inherits from DHT, but which implements the various virtual functions.
Something like:
class myDHT : public DHT {
    float getTemperature() override;
    float getHumidity() override;
The above is usually in a heder file. In the implementation file (*.cpp), you would flesh out the two functions:
float myDHT::getTemperature() {
    // do stuff to read temperature;
Then, in the sketch code, you would declare:
myDHT dht(...);
The docs for the library should have made this abundantly clear.
Cheers,
Norm.
Dude, this is perfect. I don’t know how to make a library. I think I understand how they work. But the library and the script can be really interwoven. Now you’re connecting the .cpp file, so I’m going to spend some time with these three files now to see how they interact.
I really felt like a grownup when I edited a class in a header file, not entirely understanding what I was doing. But it worked, so lots of what looks intuitive is intuitive.
Thanks.
Read this too, on your other thread.
Cheers,
Norm.
what’s this .hpp stuff?
I don’t have enough grasp to create a class, but I can edit.
In the olden days of C++, some developers used *.hpp and *.cpp for their header and source files. These days, most people use *.h for headers.
You probably could! A class is simply a model, in software, of a “thing” which exists in reality.
I saw your edit where you added float readTemperature and float readHumidity to the DHT class. You added two variables, you never update or use them.:frowning_face:
You will continue to get compilation errors until you create a new class which inherits from DHT and implements the two virtual functions. I don’t see any implementation in your code above only the header. Did you write code for those functions in your DHT11 & DHT22 classes?
I think the DHT library is a base class to allow for most of the hard work that goes into interfacing with and using a DHTxxx sensor. It’s up to the individual to write the code specific to the actual sensor in use.
HTH
Cheers,
Norm.
Are you using the right DHT library? Since the dependency graph of your code says
|-- <DHT> 1.2.1
|   |-- <Ticker> 1.1
instead of
|-- <DHT sensor library> 1.3.10
I suspect from the version number (1.2.1), and the fact that it depends on the Ticker library that you are in fact trying to use another library, simply named DHT. Using the DHT sensor library written by Adafruit, which appears to be the one you are supposed to be using since their unified sensor library is also in the include list, works fine without any change to the code you provided. :wink: I won’t mention the final giveaway was the header from the library code you edited! :open_mouth:
Log
PLATFORM: Espressif 32 (1.12.4) > Espressif ESP32 Dev Module
Found 30 compatible libraries
|   |-- <AsyncTCP> 1.1.1
|   |-- <FS> 1.0
|   |-- <WiFi> 1.0
|-- <WiFi> 1.0
Compiling .pio/build/esp32dev/src/main.cpp.o
Generating partitions .pio/build/esp32dev/partitions.bin
Compiling .pio/build/esp32dev/libc38/AsyncTCP/AsyncTCP.cpp.o
Compiling .pio/build/esp32dev/lib447/FS/FS.cpp.o
Compiling .pio/build/esp32dev/lib447/FS/vfs_api.cpp.o
Compiling .pio/build/esp32dev/lib114/WiFi/ETH.cpp.o
Archiving .pio/build/esp32dev/lib447/libFS.a
Indexing .pio/build/esp32dev/lib447/libFS.a
Archiving .pio/build/esp32dev/libc38/libAsyncTCP.a
Indexing .pio/build/esp32dev/libc38/libAsyncTCP.a
Compiling .pio/build/esp32dev/lib114/WiFi/WiFi.cpp.o
Compiling .pio/build/esp32dev/lib114/WiFi/WiFiAP.cpp.o
Compiling .pio/build/esp32dev/lib114/WiFi/WiFiClient.cpp.o
Compiling .pio/build/esp32dev/lib114/WiFi/WiFiGeneric.cpp.o
Compiling .pio/build/esp32dev/lib114/WiFi/WiFiMulti.cpp.o
Compiling .pio/build/esp32dev/lib114/WiFi/WiFiSTA.cpp.o
Compiling .pio/build/esp32dev/lib114/WiFi/WiFiScan.cpp.o
Compiling .pio/build/esp32dev/lib114/WiFi/WiFiServer.cpp.o
Compiling .pio/build/esp32dev/lib114/WiFi/WiFiUdp.cpp.o
Compiling .pio/build/esp32dev/lib015/ESP Async WebServer/AsyncEventSource.cpp.o
Compiling .pio/build/esp32dev/lib015/ESP Async WebServer/AsyncWebSocket.cpp.o
Compiling .pio/build/esp32dev/lib015/ESP Async WebServer/SPIFFSEditor.cpp.o
Archiving .pio/build/esp32dev/lib114/libWiFi.a
Indexing .pio/build/esp32dev/lib114/libWiFi.a
Compiling .pio/build/esp32dev/lib015/ESP Async WebServer/WebAuthentication.cpp.o
Compiling .pio/build/esp32dev/lib015/ESP Async WebServer/WebHandlers.cpp.o
Compiling .pio/build/esp32dev/lib015/ESP Async WebServer/WebRequest.cpp.o
Compiling .pio/build/esp32dev/lib015/ESP Async WebServer/WebResponses.cpp.o
Compiling .pio/build/esp32dev/lib015/ESP Async WebServer/WebServer.cpp.o
Compiling .pio/build/esp32dev/lib2c1/Adafruit Unified Sensor/Adafruit_Sensor.cpp.o
Archiving .pio/build/esp32dev/lib2c1/libAdafruit Unified Sensor.a
Indexing .pio/build/esp32dev/lib2c1/libAdafruit Unified Sensor.a
Compiling .pio/build/esp32dev/lib53a/DHT sensor library/DHT.cpp.o
Compiling .pio/build/esp32dev/lib53a/DHT sensor library/DHT_U.cpp.o
Archiving .pio/build/esp32dev/libFrameworkArduinoVariant.a
Indexing .pio/build/esp32dev/libFrameworkArduinoVariant.a
Compiling .pio/build/esp32dev/FrameworkArduino/Esp.cpp.o
Archiving .pio/build/esp32dev/lib53a/libDHT sensor library.a
Indexing .pio/build/esp32dev/lib53a/libDHT sensor library.a
Compiling .pio/build/esp32dev/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/IPv6Address.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/MD5Builder.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/Print.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/StreamString.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/WMath.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/WString.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/base64.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/cbuf.cpp.o
Archiving .pio/build/esp32dev/lib015/libESP Async WebServer.a
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-adc.c.o
Indexing .pio/build/esp32dev/lib015/libESP Async WebServer.a
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-misc.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-spi.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-time.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/libb64/cdecode.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/libb64/cencode.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/main.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/stdlib_noniso.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/wiring_pulse.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/wiring_shift.c.o
Archiving .pio/build/esp32dev/libFrameworkArduino.a
Indexing .pio/build/esp32dev/libFrameworkArduino.a
Linking .pio/build/esp32dev/firmware.elf
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
Checking size .pio/build/esp32dev/firmware.elf
Building .pio/build/esp32dev/firmware.bin
RAM:   [=         ]  13.4% (used 43984 bytes from 327680 bytes)
Flash: [=======   ]  69.9% (used 916409 bytes from 1310720 bytes)
esptool.py v2.6
====================================================== [SUCCESS] Took 40.67 seconds ======================================================
platformio.ini
   ESP Async WebServer
   DHT sensor library
