In a CI build with a github self-hosted runner, I was using
pio remote run --force-remote -t clean -t upload
Which worked fine - the firmware was cleaned, built and uploaded. However, because environment variables are not propagated, I had to switch to a local build, without --force-remote
When I did this, the behavior changed. Instead of building the firmware, it performed the clean operation twice, and then attempted to upload a non-existent .elf
file.
Here’s the logs
Building project locally
Processing bw_swan_r5 (platform: ststm32; board: bw_swan_r5; framework: arduino)
Removing .pio/build/bw_swan_r5
Done cleaning
========================= [SUCCESS] Took 0.40 seconds =========================
Uploading firmware remotely
Done cleaning
*** [upload] Source `.pio/build/bw_swan_r5/firmware.elf' not found, needed by target `upload'.
I was hoping there was a build
target or similar, but didn’t find one. Is there some other way to make this work? The workaround I used is to invoke pio run
twice with each target separately.
