Hi All
I’m new with Platformio in VSCode and encountered a Problem:
Error while Building:
*** [.pio/build/nano_33_iot/firmware.elf] Error 1
Hardware : Arduino Nano 33 IoT
Lib_To_Use: https://github.com/BriscoeTech/Arduino-FreRTOS-SAMD21
So I First Setup a simply Project to communicate with Arduino Nano which worked.
I downloaded the Repo from “Lib_To_Use” and unzipped it. I then added to Platformio.ini
[env:nano_33_iot]
platform = atmelsam
board = nano_33_iot
-I /Volumes/Cyberrange/Cyberrange/misc/ICS/Development/Arduino/Ressources/Arduino-FreeRTOS-SAMD21-master/src
While building the following Error Raised:
* Task wird ausgeführt: platformio run
Processing nano_33_iot (platform: atmelsam; board: nano_33_iot; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/nano_33_iot.html
PLATFORM: Atmel SAM (8.1.0) > NANO 33 IoT
HARDWARE: SAMD21G18A 48MHz, 32KB RAM, 256KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink)
- framework-arduino-samd @ 1.8.13
- framework-cmsis @ 1.40500.0 (4.5.0)
- framework-cmsis-atmel @ 1.2.2
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Found 12 compatible libraries
Linking .pio/build/nano_33_iot/firmware.elf
.pio/build/nano_33_iot/src/main.cpp.o: In function `taskMonitor(void*)':
main.cpp:(.text._Z11taskMonitorPv+0x10): undefined reference to `vTaskDelay'
main.cpp:(.text._Z11taskMonitorPv+0x34): undefined reference to `xPortGetFreeHeapSize'
main.cpp:(.text._Z11taskMonitorPv+0x54): undefined reference to `xPortGetMinimumEverFreeHeapSize'
main.cpp:(.text._Z11taskMonitorPv+0x8c): undefined reference to `vTaskGetRunTimeStats'
main.cpp:(.text._Z11taskMonitorPv+0xb8): undefined reference to `vTaskList'
main.cpp:(.text._Z11taskMonitorPv+0xde): undefined reference to `uxTaskGetStackHighWaterMark'
main.cpp:(.text._Z11taskMonitorPv+0xfa): undefined reference to `uxTaskGetStackHighWaterMark'
main.cpp:(.text._Z11taskMonitorPv+0x116): undefined reference to `uxTaskGetStackHighWaterMark'
.pio/build/nano_33_iot/src/main.cpp.o: In function `threadB(void*)':
main.cpp:(.text._ZL7threadBPv+0x20): undefined reference to `vTaskDelay'
.pio/build/nano_33_iot/src/main.cpp.o: In function `threadA(void*)':
main.cpp:(.text._ZL7threadAPv+0x24): undefined reference to `vTaskDelay'
main.cpp:(.text._ZL7threadAPv+0x36): undefined reference to `vTaskDelete'
.pio/build/nano_33_iot/src/main.cpp.o: In function `setup':
main.cpp:(.text.setup+0x4c): undefined reference to `vSetErrorLed'
main.cpp:(.text.setup+0x52): undefined reference to `vSetErrorSerial(arduino::Stream*)'
main.cpp:(.text.setup+0x68): undefined reference to `xTaskCreate'
main.cpp:(.text.setup+0x7e): undefined reference to `xTaskCreate'
main.cpp:(.text.setup+0x96): undefined reference to `xTaskCreate'
main.cpp:(.text.setup+0x9a): undefined reference to `vTaskStartScheduler'
After this I copied the content of [Path_To_Development]/Development/Arduino/Ressources/Arduino-FreeRTOS-SAMD21-master/src to the Projects src directory. And Like Magic it worked.
After Reading your docu I also learned that I can import lib_deps directly via git. So next I again deleted the files from the Project src Folder and changed my Platformio.ini to
[env:nano_33_iot]
platform = atmelsam
board = nano_33_iot
https://github.com/BriscoeTech/Arduino-FreeRTOS-SAMD21.git#v2.3.0
And Again it worked.
So my Question is:
What is the difference between those options. I Thought the "build_flags = -I […] just adds a include path to the compiler. Shouldn’t the result be the same as copying it to the Project src File ?
Greets
Sebastian
