Device monitor preview a command of "send_on_enter"
I am using the serial monitor with this following command:
pio device monitor -b 250000 -f colorize -f send_on_enter -f time
This works great but whenever I am typing a command there is no feedback on what I typed. Works in a similar way of inputting Linux passwords. So far as I looked around there is probably no option or flag to set this. In that case any chance, this could be a future feature?
Thanks in advance.
Do you mean --echo option? I’ve just opened a feature request, we will enable “echo” by default for “send_on_enter” filter:
Yes I do mean exactly that, I havent tried it because I thougth it will just loop back the message after hitting enter. Thanks!
Hello @ivankravets,
Is there a way to activate echo using the platformio.ini file?
I looked but couldn’t find it.
I looked here: pio device monitor — PlatformIO latest documentation
Thanks!
Shouldn’t that be possible via monitor_flags as these are generic? Redirecting...
monitor_flags =
   --echo
So this does work! I couldn’t figure that out reading the documentation. Thanks for your help. If you couldn’t tell, I am a beginner at this lol
