I have two scripts i run as extra_scripts. One creates a version file, the other copies the firmware from the build directory to another. The scripts work fine. However, when launching the device monitor, this causes the scripts to run again, thus incrementing the build.
[env]
platform = espressif32@5.3.0
framework = espidf
board_build.partitions = factory_app_two_ota.csv
custom_ota_port = 3232
[env:debug_home_serial]
upload_port = /dev/cu.usbserial-8344401
build_type = debug
upload_speed = 1500000
monitor_port = /dev/cu.usbserial-8344401
extra_scripts = pre:tools/buildscript_versioning.py
pre:tools/copy_firmware.py
builscript_versioning.py
Import ("env")
import datetime
import subprocess
import shutil
tm = datetime.datetime.today()
FILENAME_BUILDNO = 'versioning'
FILENAME_VERSION_H = './lib/version/version.h'
version = 'v0.1.' + str(tm.year)[-2:]+('0'+str(tm.month))[-2:]+('0'+str(tm.day))[-2:] + '_'
build_dir = env.subst("${BUILD_DIR}/")
project_firmware_dir = env.subst("${BUILD_DIR}/firmware/")
def run(*args):
return subprocess.run(['git'] + list(args))
build_no = 0
try:
with open(FILENAME_BUILDNO) as f:
build_no = int(f.readline()) + 1
firmware = f.readline()
except:
#print('Starting build number from 1..')
build_no = 1
with open(FILENAME_BUILDNO, 'w+') as f:
f.write(str(build_no)+"\n")
f.write(str(version) + str(build_no))
#print('Build number: {}'.format(build_no))
firmware_name = "firmware_%s" % version + str(build_no)
env.Replace(PROGNAME=firmware_name)
hf = """
#pragma once
#ifndef BUILD_NUMBER
#define BUILD_NUMBER "{}"
#ifndef VERSION
#define VERSION "{} - {}"
#ifndef VERSION_SHORT
#define VERSION_SHORT "{}"
""".format(build_no, version+str(build_no), datetime.datetime.now(), version+str(build_no))
with open(FILENAME_VERSION_H, 'w+') as f:
f.write(hf)
tag = version + str(build_no)
commit_message = "Updates"
build_type = env.GetProjectOption("build_type")
if build_type == "release":
subprocess.run(['git', 'add', '.'] ,stdin=None, input=None, stdout=None, stderr=None, capture_output=False, shell=False)
subprocess.run(['git', 'tag', tag] ,stdin=None, input=None, stdout=None, stderr=None, capture_output=False, shell=False)
subprocess.run(['git', 'commit', '-am', commit_message, "--quiet"])
subprocess.run(['git', 'push', 'origin', "--tags", "--quiet"])
subprocess.run(['git', 'push', "--quiet"])
copy_firmware.py
Import ("env")
import datetime
import subprocess
import shutil
project_firmware_dir = env.subst("${PROJECT_DIR}/firmware/")
def after_build(source, target, env):
try:
build_no = f.readline()
except:
pass
#("ERROR OPENING FILE")
firmware_name = "firmware_%s" % str(firmware) + ".bin"
src = build_dir + firmware_name
dst = project_firmware_dir + firmware_name
shutil.copyfile(src, dst)
env.AddPostAction("buildprog", after_build)
