I have a Arduino DUE and I’m trying to log the device monitor’s output inside a log file. When I run the command without it being a background operation it creates the logfiles as it should but when I run it as a background operation it doesn’t create any logfiles, here is the command I ran:
It also hangs when I don’t run in as a background operation, I have a shell script where I read the log file after the platfomrio device monitor is called:
While running pio in the screen session, you are able to access the log file written by the pio device monitor as usual.
To stop it just type
screen -S DM -p 0 -X stuff "^C"
The phrase DM used in the two commands is arbitrary - you can choose another you like.
For more details please have a look at serverfault
P.S.: There is no --verbose option
platformio device monitor -h
Usage: platformio device monitor [OPTIONS]
Options:
-p, --port TEXT Port, a number or a device name
-b, --baud INTEGER Set baud/speed [default=9600]
--parity [N|E|O|S|M] Enable parity checking [default=N]
--rtscts Enable RTS/CTS flow control
--xonxoff Enable software flow control
--rts INTEGER RANGE Set initial RTS line state [0<=x<=1]
--dtr INTEGER RANGE Set initial DTR line state [0<=x<=1]
--echo Enable local echo
--encoding TEXT Set the encoding for the serial port (e.g.
hexlify, Latin-1, UTF-8) [default=UTF-8]
-f, --filter TEXT Apply filters/text transformations
--eol [CR|LF|CRLF] End of line mode [default=CRLF]
--raw Disable encodings/transformations of device
output
--exit-char INTEGER ASCII code of special character that is used to
exit the application [default=3 (Ctrl+C)]
[default: 3]
--menu-char INTEGER ASCII code of special character that is used to
control terminal (menu) [default=20 (DEC)]
--quiet Diagnostics: suppress non-error messages
--no-reconnect Disable automatic reconnection if the
established connection fails
-d, --project-dir DIRECTORY
-e, --environment TEXT Load configuration from `platformio.ini` and
the specified environment
-h, --help Show this message and exit.
