Dependency of local Library not found
Hi guys,
I put a local library into my project root’s lib folder and the structure looks like this:
MyProject/
   lib/
      MyLib/
         src/
            MyLib.h
            MyLib.cpp
      library.json
   src/
      main.cpp
   platformio.ini
MyLib depends on another library, in this case it’s PubSubClient, so I have included it in both MyLib.h and MyLib.cpp via
#include <PubSubClient.h>
and in library.json I have put
  "dependencies": [
      "name": "PubSubClient"
In main.cpp I have included my lib like this:
#include <MyLib.h>
Now, when I try to build the project, the console says
Compiling .pio\build\nodemcuv2\lib8ad\MyLib\MyLib.cpp.o
lib\MyLib\src\MyLib.cpp:2:26: fatal error: PubSubClient.h: No such file or directory
* Looking for PubSubClient.h dependency? Check our library registry!
* CLI  > platformio lib search "header:PubSubClient.h"
* Web  > https://platformio.org/lib/search?query=header:PubSubClient.h
compilation terminated.
I would have expected that PIO automatically figures out that PubSubClient needs to be downloaded and makes it available within the project.
A workaround is to put PubSubClient to lib_deps in platformio.ini, but I think it would be a cleaner approach if my local lib would manage its dependencies on its own and the main project doesn’t even know about the “nested” ones…
Is this possible? Am I doing sth. wrong?
Thanks for your feedback!
That’s how I thought it worked too.
What does the dependency graph show when you start your build? Does it show PubSubClient under MyLib?
i.e. this thing …
Found 41 compatible libraries
|-- <ESPAsyncTCP> 1.2.2
|   |-- <ESP8266WiFi> 1.0
|-- <ESP Async WebServer> 1.2.2
|   |-- <Hash> 1.0
|-- <FauxmoESP> 3.1.0
|-- <ESPAsyncWiFiManager> 0.22
|   |-- <DNSServer> 1.1.1
|   |   |-- <Hash> 1.0
|-- <EasyButton> 1.1.1
|-- <ESP8266mDNS> 1.2
|-- <Ticker> 1.0
|-- <EEPROM> 1.0
|-- <ArduinoOTA> 1.0
Hi pfeerick,
thanks for your answer.
I took a look at my dependency graph, but it shows only one layer and no nested dependencies (esp-libraries is another dependency from one of my GitHub repositories):
Found 32 compatible libraries
|-- <esp-libraries> #14a83c0
|-- <MyLib>
Compiling .pio\build\nodemcuv2\src\main.cpp.o
Even if I set lib_ldf_mode to deep in my platformio.ini (in the root project), it does not change anything:
LDF Modes: Finder ~ deep, Compatibility ~ soft
|-- <MyLib>
UPDATE
When I run the build step in verbose mode (-v), it says that the PubSubClient library is being ignored. But why is that?
Warning: Ignored `PubSubClient` dependency for `MyLib` library
|-- <ESP8266WiFi> 1.0 (C:\Users\Philippe\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi)
|-- <MqttHandler> (C:\development\platformio\morse-project\lib\MqttHandler)
Do you have any idea what’s going wrong?
Why is there a library.json in the lib/ folder and not in the MyLib folder? What’s the content of this very critical file? What’s the platformio.ini?
Hi maxgerhardt,
oh, thanks for pointing that out - actually the library.json is placed within the MyLib folder. It has just the wrong indentation in my first post. So here’s the correct structure:
MyProject/
   lib/
      MyLib/
         src/
            MyLib.h
            MyLib.cpp
         library.json
   src/
      main.cpp
   platformio.ini
And here’s the content of the library.json:
  "dependencies": [
The platformio.ini in the root project:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
Is anything wrong with that?
Maybe it doesn’t like it when you specify the library without a version number. Try using the documentated short form.
Also you’re not putting in any of the values which are marked as required in the doc – your library must have at least a name, version, description, keywords and repository in the library.json.
Try with a library.json like:
  "name": "MyLib",
  "description": "My test library",
  "keywords": "keyword1,keyword2",
  "version": "1.0.0",
  "repository":
      "type": "git",
      "url": "<your actual .git link here>"
  "dependencies":
     "PubSubClient": "^2.8"
Did anyone get this to work? I’m after the same feature and am experiencing the same issue…
I also have this issue.
I don’t know if this is the “right” way, but this is what worked for me: (my lib is ppl)
  1. remove dependency from your platform.io
  2. delete dependency from .pio/libdeps
  3. start a PlatformIO terminal
  4. pio lib install lib/ppl
# This is before deleting the ppl directory from libdeps:
force-majeure % pio lib install lib/ppl
Library Storage: /Users/josh/github/pyrogenic/force-majeure/.pio/libdeps/nanoatmega328new
Library Manager: ppl @ 0.0.0+20210307111859 is already installed
# This is after deleting the ppl directory from libdeps:
Library Manager: Installing file://lib/ppl
Library Manager: ppl @ 1.1.0 has been installed!
Library Manager: Installing dependencies...
Library Manager: Installing milesburton/DallasTemperature @ ^3.9.1
Library Manager: DallasTemperature @ 3.9.1 has been installed!
Library Manager: Installing paulstoffregen/OneWire @ ^2.3.5
Library Manager: OneWire @ 2.3.5 has been installed!
