I have some folder structure like that :
\_lib
\_lib1
\_lib1.h
\_lib1.cpp
\_lib2
\_lib2.h
\_lib2.cpp
And my code was compiling until i made some clean inside .h for redundant call. Now it is like that :
main.h ;
#include "lib1.h"
lib1.h :
#include "lib2.h"
lib2.h :
#include "lib3.h"
#include "lib4h"
And i get that error :
fatal error: lib3.h: No such file or directory
But, if i add lib3/lib4 inside lib1 its ok (there are not need there):
main.h ;
#include "lib1.h"
lib1.h :
#include "lib2.h"
#include "lib3.h"
#include "lib4h"
lib2.h :
#include "lib3.h"
#include "lib4h"
Is it normal ? PlatformIO related or precompiler related ?
Thanks in advance
What does the complete folder structure of this project look like?
Was created with platformio
_include
_lib
__lib1
____lib1.cpp
____lib1.h
_src
__main.cpp
__main.h
_test
That doesn’t look like the complete folder structure…
So you have 4 libraries in your lib folder (lib1 to lib4) ??
Is there a lib3.h present?
I have 8 libs which i wrote, its why i didn’t put them
The directory structure are all the same, for example a SPI/I2C lib :
SPI
\_SPI.h
\_SPI.cpp
I2C
\_I2C.h
\_I2C.cpp
And they partially depends on each other?
Any chance to get a look at your project? (github?)
Sorry, you edit/reply faster than me
I edited previous post
No github for now, they depends each other with no loop call (in case of)
and yes, lib3 exist, if i call it from lib1, compilation work
It’s not about where libraries are called from.
This whole thing is ONE project.
Let me prepare an example…
Example:
File structure:
├── lib
│ ├── LibA
│ │ ├── LibA.cpp
│ │ └── LibA.h
│ └── LibB
│ ├── LibB.cpp
│ └── LibB.h
├── src
│ └── main.cpp
└── platformio.ini
lib/LibA/LibA.h
#pragma once
int function_from_libA();
lib/LibA/LibA.cpp
#include "LibA.h"
int function_from_libA() {
return 42;
lib/LibB/LibB.h
#pragma once
int function_from_libB();
lib/LibB/LibB.cpp
#include "LibB.h"
#include "LibA.h"
int function_from_libB() {
return function_from_libA() + 1; // should be 43
src/main.cpp
#include <LibB.h>
Serial.println(function_from_libB());
void loop() {}
LibB depends on LibA - No issues here…
Output:
43
Working on it, i try to reproduce it with simple archi like yours.
finally, was my mistake (as usual ? ^_^)
I got 2 .cpp inside a lib, i moved it in another folder and now it works. I don’t understand why it works if i call another lib before.
Thanks for your work
Without seeing the code I can only guess.
Maybe it’s because you included some header files in another header file…
But that’s just a gues.
I’m glad you were able to fix it
