I retried to enter the code on my board withour pressing the reset button again, and now this error message appears:
I’m out of my depth here, you may have better chances at the general Arduino forum or AVRdude discussion in regards to what protocol / flags you need for flashing: avrdudes/avrdude · Discussions · GitHub
Ok, thank you nevertheless.
But do I have to press the reset button or not?
I received good help here regarding the flashing of the firmware:
Now I would like to send some data from the custom board to a terminal prgram via the serial interface. Unfortunately, I can’t select a serial port that belongs to my board in Docklight, for example. Do I have to install any drivers? Or have I possibly installed the wrong one?
Thanks in advance!
Well what’s the sketch you’re uploading to the board? Does it have Serial.begin();
in it?
It’s this:
tft.begin();
Serial.begin(9600);
String inString = “”;
while(Serial.available() > 0)
char inChar = Serial.read();
inString += inChar;
delay(10);
if(inString != “”)
Serial.println("Input string: ");
Do I need a USB terminal programme, instead of a virtual com-port terminal programm, to communicate between my custom board and the PC?
Before doing any of the more complicated USB / TFT stuff, have you verified that you can blink a simple LED?
change LED_BUILTIN
to whatever, pin mapping is per here.
If that’s not working, something is totally not right. You might be running into a situation where the sketch is being uploaded to the wrong address with regards to your chip’s currently set fuses / no Arduino bootloader situation, thus resulting in nothing being run actually.
