I’m at a project with an esp32 using a touch tft display an sd-card and gps module.
The platformio.ini is this:
[platformio]
name =
description =
[env]
board = esp32doit-devkit-v1
mikalhart/TinyGPSPlus @ ^1.1.0
upload_port = COM8
[env:build]
build_type = release
-D AZD_2P4TFT_COLDISP
-Wfatal-errors
; -v
[env:debug]
build_type = debug
-D CORE_DEBUG_LEVEL=5
-D DEBUG_LEVEL=3
-Og
-g2
-D DEBUG
; -D TOUCH_CS
-Wfatal-errors
; -v
debug_tool = esp-prog
The includes in the main.cpp are:
#include "HW_DEV-Kit_V1.h"
#include <TFT_eSPI.h>
#include "main.h"
The include-files in <> are at the standard location of all standard libraries of
platformio and the include-files in “” are in the lib folder of the project.
As I want to have the definition of all pins of my used board in one file I use the header file “HW_DEV-Kit_V1.h”. There is the definition of “TOUCH_CS”.
When I compile i get the error:
In file included from C:/Users/heinz/.platformio/packages/framework-arduinoespressif32/libraries/myTFT_eSPI/TFT_eSPI.cpp:16:
C:/Users/heinz/.platformio/packages/framework-arduinoespressif32/libraries/myTFT_eSPI/TFT_eSPI.h:973:8: warning: #warning >>>>------>> TOUCH_CS pin not defined, TFT_eSPI touch functions will not be available! [-Wcpp]
If anybody could give an advise I would be happy.
