Default project folder?
I wonder a little WHEN this setting comes in use !
I have these settings:
but when I wnat to open an existing project fra the PIO Home I get this dialog:
and when I in fact opens a project, finish my work there, remove the folder from the workspace and wants to add another folder it REMEMBERS my LAST project and present THAT open project folder for me !!!
The ONLY place I found it uses the default project folder is when I’m creating a new project - then a checkmark tells me it’s created at the ‘default location’:
billede
Do I mis something here OR is this the ‘designed’ way the default project folder is supposed to work ?
You can write suggestions for UI improvements as issues in Issues · platformio/platformio-vscode-ide · GitHub.
