It seems that with some latest update the default log level has been fixed to Error, where i could vary it depending on my needs before. I am using the Arduino env.
What worked before is to either set
Neither works on a full re-install of Visual Studio Code with platform.io IDE plugin. Interestingly it still works on the other computer with a somewhat older VS Code installation, but updated (0.9) platform.io plugin.
I wonder how i could go on here… I wonder whether i need to compile my own version of the platform.io esp32 lib… how would i do this?
I discovered the same problem. In my application i see only logs of level error, no logs of evel info or warning. Tried several log settings, no success. Help needed…
Meanwhile i found the root cause, but the workarounds described here and here both do not work with PlatformIO platform Espressif32 with framework arduino
Set log level for a specific project Edit platformio.ini (located in the project folder) Add (or extend) the build_flags option: **build_flags = -DCORE_DEBUG_LEVEL=ARDUHAL_LOG_LEVEL_DEBUG**
I tried your solution and it doesn’t work for me.
I am setting my build flags in platformio.ini as this, I want log level info.
-DCORE_DEBUG_LEVEL=3
-DCONFIG_ARDUHAL_LOG_DEFAULT_LEVEL=3
However, i cannot even see esp error logs.
I checked the value of this definitions at runtime and they are ok ( all 3 which is esp info level):
ARDUHAL_LOG_LEVEL
CONFIG_LOG_DEFAULT_LEVEL
CORE_DEBUG_LEVEL
