Hi im using PIO for esp32 module development in Arduino framework. I have some code that I did not write that declares variables such as:
unsigned int
What is the defaut for this…is it an 8-bit, 16-bit, etc.?
Based on the answer, is there a way to globally change the default?
Thanks!
Mark
ESP32/XTensa32 has an int
size of 32-bits / 4 byytes.
You can see that for yourself by inspecting sizeof(int)
in the IDE or at runtime, or looking at the INT_MAX
/ INT_MIN
macros from limits.h
If you wanted your application to use fixed-width integers, it should have been written using stdint.h
types instead, such as int32_t
, uint16_t
, etc.
As far as I know, there are no compiler settings for the XTensa GCC to arbitrarily change the size of the fundmental types (int
, short
, char
, long
, etc).
