Default_envs = cyd
Hello Community I fiddle with the fantastic LVGL and a cheap Yellow Display.
My question “default_envs = cyd” how can I change the Value cyd
The default_envs — PlatformIO latest documentation does not tell how to handle default_envs
Sorry I got it I can define it in a section like this
[env:esp32devCYD_STOCK]
But the documentation clearly sates “default_envs allows one to define which environments that should be processed by default.”
You have a platformio.ini with multiple env entries like:
[env:esp32]
[env:esp8266]
[env:uno]
[env:teensy]
With default_envs you just specify the environment which is processed if none is explicit selected in the project environment switcher.
