Hi all,
I have been attempting to google this problem as it seems like a very simple problem to solve yet no answers have provided me with a solution that works (or one that actually reflects my issue) so I appreciate your patience.
I am slowly transitioning from the Arduino IDE to platformIO, and in order to have my entire project transfer, I moved everything into a single file (bad practise I know, but it was the only way I could figure it out at the time to move to this platform and get this project on github). I have now been slowly moving functions into appropriate cpp files as I’m starting to figure out that process from this guide:
https://community.platformio.org/t/tutorial-for-creating-multi-cpp-file-arduino-project/5830
My question is: How do I declare the struct so that I do not get the error “src\loadcell.cpp:30:3: error: ‘conf’ was not declared in this scope”?
Here is the relevant code:
main.cpp
struct config_t {
uint16_t conf_valid;
long lora_freq; // 4
int lora_syncword = 0x12;
long lora_bw = 250000;
int lora_spread = 10;
int lora_coderate = 5;
int power = 12;
uint32_t send_interval_mins = 1;
uint32_t lc_min = 85000;
uint32_t lc_max = 6500000;
uint32_t weight_max = 100;
int32_t resistor1 = 3300000;
int32_t resistor2 = 560000;
byte ir1ena = 1;
byte ir2ena = 1;
byte pir1ena = 0;
int16_t battOffset = 0;
uint8_t sensorModel; // 1
uint32_t id; // 4
uint8_t id_has_been_set;
uint8_t sType[16];
uint8_t wakeups_per_sec;
boolean enable_gyro;
uint8_t country;
float zero_cal_temperature; // Temperature is stored here on power up for load cell zero calibration
int32_t zero_cal_offset_raw; // Raw offset from 0 - 200g, added to zero cal for load cell when unit powered on
int32_t last_reading_raw;
float gyro_activity = 0.3;
int32_t K = 1;
} conf;
loadcell.h:
#ifndef LOADCELL_H
#define LOADCELL_H
#include <stdint.h>
#include "Arduino.h"
void setup();
void loop();
void HX711_power_off();
void HX711_power_on();
void HX711_power_on_zero();
int32_t HX711_read();
bool HX711_is_ready();
int32_t read_scale_average(uint8_t avg);
void read_tc();
#endif //
loadcell.cpp
#include <stdint.h>
const byte Pin_HX_DOUT = 22;
const byte Pin_HX_SCK = 23;
const byte Pin_TMPV = 2; // ADC2 - function uses the number only so 7 doesn't mean digital pin 7
const byte Pin_SPWR = 28; // ** NEW Pin, D14/A0 = power for HX711 and Temp sensor High=on
float temperature = 0.0;
boolean USB_Enabled = false;
void read_tc();
void HX711_power_on(){
pinMode(Pin_TMPV, INPUT);
pinMode(Pin_SPWR, OUTPUT); // D5 = Load Cell & temperature sensor Power
digitalWrite (Pin_SPWR, HIGH); // Turn on
delay(2);
pinMode(Pin_HX_DOUT, INPUT); // D5 = Load Cell Data
pinMode(Pin_HX_SCK, OUTPUT); // D5 = Load Cell Clock
void HX711_power_on_zero(){
HX711_power_on();
if (USB_Enabled == true){
Serial.println(F("Power On - ZERO Calibrate"));
delay(10);
read_tc();
conf.zero_cal_temperature = temperature; //This is where the conf error occurs
Serial.print(F("Cal TC = "));
Serial.println(temperature);
There are 100’s of lines of code in this cpp file so I hope i’ve included enough to give the context.
Surely this is a simple question but I’ve been wrong before and I’ll be wrong again, any help will be greatly appreciated even if its sending me to a resource I didn’t see.
Cheers,
Dylan
