Hi …
I’m using Eclipse and want to debug with PIO but it did not work. When I want to start debugging I can see that a build is performed, that succeeds, then there is longer break where nothing happens then I get a error
Error in services launch sequence
Timed out trying to launch GDB.
Whats wrong here?!
My Eclipse Version:
IDE for C/C++ Developers
Version: Oxygen.2 Release (4.7.2)
Build id: 20171218-0600
OS: Linux, v.4.4.0-119-generic, x86_64 / gtk 3.18.9
PIO Versions:
julian@DevVm64-04:~$ pio update
Updating tool-scons @ 2.20501.4 [Up-to-date]
Updating tool-unity @ 1.20403.0 [Up-to-date]
Updating contrib-pysite @ 0.2.0 [Up-to-date]
Updating contrib-piohome @ 0.9.5 [Up-to-date]
Updating tool-pioplus @ 1.1.7 [Up-to-date]
Platform Manager
Platform Atmel AVR
Updating atmelavr @ 1.8.1 [Up-to-date]
Updating toolchain-atmelavr @ 1.40902.0 [Up-to-date]
Platform Native
Updating native @ 1.1.1 [Up-to-date]
Platform ST STM32
Updating ststm32 @ 4.1.0 [Up-to-date]
Updating tool-stm32duino @ 1.0.0 [Up-to-date]
Updating framework-arduinoststm32 @ 2.1.180219 [Up-to-date]
Updating toolchain-gccarmnoneeabi @ 1.70201.0 [Up-to-date]
Updating tool-stlink @ 1.10400.0 [Up-to-date]
Updating tool-openocd @ 1.1000.4 [Up-to-date]
Updating framework-spl @ 1.10201.0 [Up-to-date]
Updating framework-stm32cube @ 1.1.0 [Up-to-date]
Updating framework-mbed @ 4.50707.0 [Up-to-date]
Library Manager
julian@DevVm64-04:~$ pio upgrade
You’re up-to-date!
PlatformIO 3.5.3a9 is currently the newest version available.
Could you share your platformio.ini?
As requested …
[env:nucleo_f103rb]
platform = ststm32
board = nucleo_f103rb
framework = stm32cube
lib_ldf_mode = deep+
build_flags = -Icfg -DUSE_FULL_LL_DRIVER
upload_protocol = jlink
debug_tool = jlink
Has someone a hint for me?
Well … in VS Code the debugger starts and I can do single steps but there are the following problems:
- The debugger cant be stopped because it gets automatically restarted all the time
- It seams not to be possible to add structs to the watch list to keep a eye on peripherals (e.g. GPIOA) and type casting does not help at all.
- The watched values can’t be displayed as hex values … and it’s annoying to convert 4577864 to a hex mask with the calculator to figure out which bit has been set.
- Atom performs better but can’t display hex values either …
I’m using Ubuntu 16.04LTS 64Bit, my system gets updated frequently, VS Code and Atom are up to date as well pio. Currently I’m working on a nucleo-F103RE and the stlink is re flashed as J-Link (also up to date).
When using the GnuArmEclipse plugin things are working as expected … pio would be more attractive to go with as it is a generic solution for all mcu’s i might to or have used so far.
Ping …
My trail expires in some days … any news on debugging with eclipse?
You sell this as supported … from my pint of view it isn’t and for now I see no reason to pay for a account
But I would if this works … or if there is support to get it working.
Regarding the option to use VS Code … any progress or news here?
br J.
Well never the less you are still promoting the support. Anyway … I can’t try the update for VSCode anymore as my trail has expiered before it has been released.
Please re-login! I’ve just reset your trial. Thanks!
Long time no see
So finally I’m convinced … debugging in vscode works now at least for me pretty well. As Ice-T stated during a Body Count concert …
Their’s always room form improvement!
Can’t believe that I quote Ice-T in this context but he really said this … he was talking about Moshpit’s but imho that does not make that difference
What I wold like to see is …
Some kind of highlighting when a peripheral register changes and it’s content. Eclipse does this whenever the debugs halt’s the target by showing the deltas compared to the last the the target was halted.
Being able to switch to a hexadecimal view for a given variable. As far I have got it right this is a common vscode issue which might be solved be a upcoming vscode release. So lets wait a while and see how this turns out.
pio has support for the native environment, but the new pio project wizard in vscode does not offer native as board although it would work. To test this out I have created such a native project and opened it in vscode. I was able to compile it but the executable cant be started in vscode or debugged. In the terminal it war working so I know thet the core is working well. If you ask yourself why this might be needed … Well, from time to time I want to try things out in the host while creating a new algorithm and do some tests with if by using much debug output and so on. In eclipse I have always created a native C project and was ready to go in seconds … once done I moved the code to my embedded project and sometimes deleted the test project right away. In fact thats not needed with pio as a new project for the embedded target is also ready very fast, but I wan’t to mention this point anyway … at least to report my finding
Surprisingly nothing more for now.
Actually I seriously thinking about leaving eclipse behind and use vscode from now on, and I think I will buy a enthusiast pio account as this what I am
br J.
