Debugging with VSCode - set next statement
Hey!
I am looking for a functionality that’s similar to the Lauterbach’s “Set program counter”. I saw that within the VSCode community this is called Set Next Statement.
Note - this is different than the run to click, which would normally set a breakpoint ahead and would stop there. What I am looking for here is to manually change the program counter by easily clicking where in the code (either source or dissassembled) I want to change the execution flow to. Is that possible with the PlatformIO debugging integration?
Thanks
There’s only “Run to cursor” when you right click on a line of code while debugging.
I think VSCode doesn’t expose a “Force execution to start here” thing because as Microsoft says,
Moving the next statement to another function or scope usually causes call-stack corruption
So only expert users will want to use this in extremely rare cases.
However, since you do have access to the GDB console through the “Debug Console” Tab…
… you can tell GDB to modify the register responsible for the program counter which is exposed as $pcin GDB. (real register is EIP / RIP on x86/x64, PC on ARM etc…) to a specific address, which itself can be found through disas <function name> commands.
E.g., given the code above and state above, and I want to move to beginning of the “sort” call, I use
=> 0x00007ff6142c1863 <+9>:	lea    0x37e6(%rip),%rcx        # 0x7ff6142c5050
   0x00007ff6142c186a <+16>:	call   0x7ff6142c2ee0 <puts>
   0x00007ff6142c186f <+21>:	movl   $0x8,0x20(%rsp)
   0x00007ff6142c1877 <+29>:	movl   $0x22,0x24(%rsp)
   0x00007ff6142c187f <+37>:	movl   $0xd,0x28(%rsp)
   0x00007ff6142c1887 <+45>:	movl   $0x11,0x2c(%rsp)
   0x00007ff6142c188f <+53>:	movl   $0x22,0x30(%rsp)
   0x00007ff6142c1897 <+61>:	movl   $0x5a,0x34(%rsp)
   0x00007ff6142c189f <+69>:	movl   $0x30,0x38(%rsp)
   0x00007ff6142c18a7 <+77>:	movl   $0x48,0x3c(%rsp)
   0x00007ff6142c18af <+85>:	movl   $0x32,0x40(%rsp)
   0x00007ff6142c18b7 <+93>:	movl   $0x56,0x44(%rsp)
   0x00007ff6142c18bf <+101>:	lea    0x20(%rsp),%rcx
   0x00007ff6142c18c4 <+106>:	mov    $0x9,%r8d
   0x00007ff6142c18ca <+112>:	mov    $0x0,%edx
   0x00007ff6142c18cf <+117>:	call   0x7ff6142c17cb <sort>
   0x00007ff6142c18d4 <+122>:	mov    $0x0,%eax
   0x00007ff6142c18d9 <+127>:	add    $0x58,%rsp
   0x00007ff6142c18dd <+131>:	ret
End of assembler dump.
then recognize that the call to sort starts with preparing the registers used for storing the argument values at 0x00007ff6142c18bf, and thus do
=> 0x00007ff6142c18c4 <+106>:	mov    $0x9,%r8d
and the line was changed and one instruction was executed, which is reflected again in the GUI.
Of course in this case, the initialization of the array input_array on the stack was skipped (movl $0x8,0x20(%rsp) etc. instructions), so the function will run on completely random data from the stack. But, that’s exactly what forcing the next statement address causes in this case.
