Debugging with Atmel-ICE on Custom Arduino micro board
Information:
I got a custom board (without much information). It has a USB-C Port and a 6pin-ISP-Interface.
It seems to imitate a Ardunio Micro since Arduino IDE 2 automatically detects it as that.
The uC is an Atmega32u4.
I managed to flash it via MPLAP-IPE (Got a .hex-File from another developer).
It’s also possible to flash it via USB (COM port in Arduino IDE 2).
The source-code is written in “Arduino C++” => .ino files.
I wanna use PlatformIO on VSCode.
Question:
My goal is to flash and debug it via Atmel-ICE (on the ISP-Interface).
Basic question: Is that possible with PlatformIO? Since it isn’t possible with the Arduino IDE 2.
I’ve tried different things, but didn’t get it to work.
My platformio.ini:
[env:micro]
debug_build_flags = -Os
debug_tool = atmel-ice
board = micro
upload_protocol = atmel-ice
DebugInvalidOptionsError: Unknown debug tool atmel-ice.
Please use one of simavr or custom
I think the problem is, that the micro board doesn’t support atmel-ice by default.
I also tried adding a custom board, but I couldn’t figure out how to manipulate the JSON.
I copied the original from GitHub and modified these parts:
"debug": {
    "tools": {
      "atmel-ice": {
        "onboard": false
    "simavr_target": "atmega32u4"
"name": "microice",
(also changed the board to microice)
:3333: The system tried to join a drive to a directory on a joined drive.
I guess either it is not possible at all or my custom board JSON is wrong.
I made progress!
I’m now able to flash the uC (upload firmware) via Atmel-ICE and ISP-Interface.
platformio.ini:
[env:micro]
debug_tool = atmelice_isp
board = microice
upload_protocol = atmelice_isp
upload_flags = -e
upload_port = usb
custom board modifications (atmelice_isp):
"name": "microice",
"upload": {
  "disable_flushing": true,
  "maximum_ram_size": 2560,
  "maximum_size": 28672,
  "protocol": "atmelice_isp",
  "require_upload_port": true
"debug": {
  "tools": {
    "atmelice_isp": {
      "onboard": false
Debugging still doesn’t work, but I’m on it.
I would be happy if someone could help me!
