So I’ve been using PlatformioIDE for a while now, and it’s been great! But I wonder: is there an easy way of initiating a debug session in GDB?
For now I’m using OpenOCD (started in a separate command prompt), and then starting arm-none-eabi-gdb (in yet another terminal).
I’ve found this example about using GDB to upload code, is there a way of using it to also debug code directly from the IDE’s terminal, without the need to load many separate windows and/or third party gdb servers like OpenOCD?
