I cannot get started debugging this board no matter what I try. I have used Zellig to install the FDTI 0 driver and here is my platformio.ini
file:
[env:sparkfun_esp32_iot_redboard]
board = sparkfun_esp32_iot_redboard
upload_protocol = esp-prog
debug_tool = esp-prog
SPI
arduino-libraries/Arduino_JSON @ 0.1.0
esphome/AsyncTCP-esphome@^2.1.0
esphome/ESPAsyncWebServer-esphome@^3.1.0
The following is the list of problems in the debug window when I start the debugger:
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : clock speed 5000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: Unexpected OCD_ID = ffffffff
Warn : target esp32.cpu0 examination failed
Warn : target esp32.cpu1 examination failed
Info : starting gdb server for esp32.cpu0 on pipe
Error: Target not examined yet
Error executing event gdb-attach on target esp32.cpu0:
Warn : No symbols for FreeRTOS!
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Error: error during select: Unknown error
Remote communication error. Target disconnected.: Success.
I would greatly appreciate some help with tracking down what I am doing wrong.
Regards,
Ron
