Hi, I’m regularly using JLink firmware instead of STLink V2/V2-1 on many Discovery and lately Nucleo boards, mainly STM32F4 series, as it is much more capable than stock firmware. It is freely available from Segger. Is there a way to define jlink gdb-based debugger for these boards?
My guess is that ~/.platformio/platforms/ststm32/boards/*.json should contain the new definition, but could not find the appropriate setup.
Thanks,
Lubos
Sure, we can add new debug tool. What is your board for a test?
Hi Ivan,
As far as I’m concerned, STM32 Discovery boards (F4, L1, F152, F030), plus Nucleo F446RE would suffice. Having that option for all STLink-based boards could be helpful for others as well, because JLink firmware is universal.
EDIT: I can test your modification immediately using F4 or F446 mentioned above.
EDIT 2: ST-LINK On-Board
Thanks in advance,
Lubos
Update: I made some progress.
After installing Segger GDB install package for my OS (.deb) and connecting Nucleo-F446RE board, the following command line makes GDB identify the part and wait for commands:
$ JLinkGDBServer -device STM32F446RE -if SWD
SEGGER J-Link GDB Server V6.12e Command Line Version
JLinkARM.dll V6.12e (DLL compiled Jan 6 2017 17:21:51)
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: yes
Generate logfile: off
Verify download: off
Init regs on start: off
Silent mode: off
Single run mode: off
Target connection timeout: 0 ms
------J-Link related settings------
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
------Target related settings------
Target device: STM32F446RE
Target interface: SWD
Target interface speed: 1000kHz
Target endian: little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link STLink V21 compiled Dec 21 2016 15:10:59
Hardware: V1.00
S/N: 776042930
Checking target voltage...
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target...Connected to target
Waiting for GDB connection...
The tool mentions DLL but still, this is Debian GNU/Linux.
We have just released new PIO Core+ v0.8.11 with a support for custom debugging configuration. Please run pio update
command.
See
Custom build feature for custom JLink GDB server as documented above prints an error in Atom:
Error launching PIO Debugger
Error: Flushed due to previous errors.
The result is the same for both setups.
Any idea on how to get more verbose output?
Environment:
- Ubuntu 16.04 amd64, Nucleo-F446RE with JLink firmware
- Windows 7 amd64, JLink JLink Nucleo-F446RE with JLink firmware
Thanks
Thanks a lot! Example has been updated
