I am new to platformio, getting to debug now. I set platformio with the avr-stub and it appears to work fine, until I load a project that includes a ssd1306 display. While the project works fine when uploading the code (no debugging), in debugging always get stuck in the TWI initialization.
After I try to step out I get:
../../gdb/gdb/infrun.c:1986: internal-error: resume: Assertion `pc_in_thread_step_range (pc, tp)' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session?
(y or n) [answered Y; input not from terminal]
This is a bug, please report it.
For instructions, see:
<http://www.gnu.org/software/gdb/bugs/>
Any special settings I am not aware? Does anybody had experience with TWI, I2C, or even SPI debugging?
Thank you, but with this chain appears not to even to start debugging. I can compile ok. But on debugging I get:
========================= [SUCCESS] Took 14.48 seconds =========================
Reading symbols from C:\Users\RICKH\Downloads\pio\.pio\build\megaatmega2560\firmware.elf...
Dwarf Error: Could not find abbrev number 3752 in CU at offset 0x117af [in module C:\Users\RICKH\Downloads\pio\.pio\build\megaatmega2560\firmware.elf]
Warning: 'set target-async', an alias for the command 'set mi-async', is deprecated.
Use 'set mi-async'.
PlatformIO: debug_tool = avr-stub
Dwarf Error: Cannot find DIE at 0x193be referenced from DIE at 0x6f7a [in module C:\Users\RICKH\Downloads\pio\.pio\build\megaatmega2560\firmware.elf]
Then I also tried the last tool chain from Microchip 3.7 and the results are like the original with Platformio toolchain-atmelavr 1.7, debugs but gets stuck in the I2C initialization
