I’m trying to set up a full environment to program a LSM100A (ST NUCLEO WL55JC like) board.
I succeeded to add the STM32cube WL framework thanks to this:
I added a main.h and a main.c that make a led blink, launched the debugger and got this error:
Function “main” not defined
Processing nucleo_wl55jc (platform: ststm32; board: nucleo_wl55jc; framework: stm32cube)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_wl55jc.html
PLATFORM: ST STM32 (17.0.0) > ST Nucleo WL55JC
HARDWARE: STM32WL55JC 48MHz, 64KB RAM, 256KB Flash
DEBUG: Current (stlink) On-board (stlink) External (cmsis-dap, jlink)
- framework-stm32cubewl @ 1.3.0
- tool-ldscripts-ststm32 @ 0.2.0
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Warning! Cannot find the default startup file for `stm32wl55jc`. Ignore this warning if the startup code is part of your project.
Found 12 compatible libraries
Building in debug mode
Checking size .pio\build\nucleo_wl55jc\firmware.elf
RAM: [ ] 0.0% (used 28 bytes from 65536 bytes)
Flash: [ ] 0.0% (used 88 bytes from 262144 bytes)
========================= [SUCCESS] Took 1.20 seconds =========================
Reading symbols from c:\Users\Cyrille\Documents\PlatformIO\Projects\tot\.pio\build\nucleo_wl55jc\firmware.elf...
(no debugging symbols found)...done.
Licensed under GNU GPL v2
For bug reports, read
hla_swd
none separate
adapter speed: 480 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 480 kHz
Info : STLINK V2J42S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.191704
Info : [stm32wlx.cpu0] Cortex-M4 r0p1 processor detected
Info : [stm32wlx.cpu0] target has 6 breakpoints, 4 watchpoints
Info : starting gdb server for stm32wlx.cpu0 on pipe
[stm32wlx.cpu0] halted due to debug-request, current mode: Handler HardFault
xPSR: 0x00000003 pc: 0xf3af4804 msp: 0x4c05b4f0
Info : device idcode = 0x10016497 (STM32WLE/WL5x - Rev 'unknown' : 0x1001)
Info : RDP level 0 (0xAA)
Info : flash size = 256 KiB
Info : flash mode : single-bank
Info : OTP size is 1024 bytes, base address is 0x1fff7000
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1012 ms). Workaround: increase "set remotetimeout" in GDB
0xf3af4804 in ?? ()
Info : Unable to match requested speed 500 kHz, using 480 kHz
[stm32wlx.cpu0] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0xb9337822 msp: 0x4c05b510
Loading section .text, size 0x58 lma 0x8000000
Loading section .init_array, size 0x4 lma 0x8000058
Loading section .fini_array, size 0x4 lma 0x800005c
Start address 0x8000000, load size 96
Transfer rate: 539 bytes/sec, 32 bytes/write.
Function "main" not defined.
Make breakpoint pending on future shared library load? (y or [n]) [answered N; input not from terminal]
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
Any ideas?
