The problem is when the “Start Debugging” is invoke the break at setup never occurs.
The blue scrolling bar in the upper left corner scrolls by several times but stops after
several seconds.
I’ve had this working in the past but can’t seem to narrow down the issue.
I’ve tried reloading zadig/ftdi drivers, PIO.
Checked wiring and all connections.
Searched for possible solutions.
Nothing seems to resolve my issue.
I’ve included the following outputs/logs.
- Platformio.ini
- Debug Console output
- Verbose log
From PIO terminal > pio run -t upload -v
and nothing seems to be an issue, see output below.
Any input would be appreciated.
================== Platformio.ini ========================
=============== Debug Console output ==================
Reading symbols from c:\Users\jake\Documents\PlatformIO\Projects\TestFiles\Test_blink\.pio\build\esp32dev\firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 10 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_ACCESS
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description '*', serial '*' at bus location '*'
Warn : Flash driver of esp32.flash does not support free_driver_priv()
Warn : Flash driver of irom does not support free_driver_priv()
I’ve been trying to connect to JTAG with my ESP32.
I’ve looked at several posts and tried diff things but no solution.
I’ve checked and rechecked my wiring, ftdi and zadig and it seems to be ok.
====================== Verbose Log =========================================
C:\Users\jake\Documents\PlatformIO\Projects\TestFiles\Test_blink>pio run -t upload -v
Processing esp32dev (platform: espressif32; board: esp32dev; framework: arduino; monitor_port: COM3; upload_port: COM11; debug_tool: esp-prog; debug_init_break: tbreak setup; upload_protocol: esp-prog; build_type: debug)
-------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32dev.html
PLATFORM: Espressif 32 (1.11.2) > Espressif ESP32 Dev Module
- tool-openocd-esp32 1.1000.20190709 (10.0)
Framework incompatible library C:\Users\jake\.platformio\lib\SoftwareSerial_ID2728
Found 29 compatible libraries
More details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
Building in debug mode
<lambda>(["checkprogsize"], [".pio\build\esp32dev\firmware.elf"])
MethodWrapper(["checkprogsize"], [".pio\build\esp32dev\firmware.elf"])
RAM: [ ] 4.7% (used 15348 bytes from 327680 bytes)
Flash: [== ] 16.1% (used 211017 bytes from 1310720 bytes)
.pio\build\esp32dev\firmware.elf :
section size addr
.rtc.text 0 1074528256
.rtc.dummy 0 1073217536
.rtc.force_fast 0 1073217536
.rtc_noinit 0 1342177792
.rtc.force_slow 0 1342177792
.iram0.vectors 1024 1074266112
.iram0.text 55612 1074267136
.dram0.data 9532 1073470304
.noinit 0 1073479836
.dram0.bss 5816 1073479840
.flash.rodata 45388 1061158944
.flash.text 99461 1074593816
.debug_frame 78632 0
.debug_info 1391175 0
.debug_abbrev 175510 0
.debug_loc 513244 0
.debug_aranges 30912 0
.debug_ranges 33096 0
.debug_line 690794 0
.debug_str 894409 0
.comment 419 0
.xtensa.info 56 0
.xt.prop._ZTV9Printable 12 0
.xt.lit._ZN9IPAddressD5Ev 0 0
.xt.prop._ZN9IPAddressD5Ev 0 0
.xt.prop._ZN9IPAddressD2Ev 36 0
.xt.prop._ZN9IPAddressD0Ev 36 0
.xt.prop._ZTV9IPAddress 12 0
.xt.lit._ZN5Print5writeEPKc 8 0
.xt.prop._ZN5Print5writeEPKc 60 0
.xt.lit._ZN6String4initEv 8 0
.xt.prop._ZN6String4initEv 60 0
.xt.prop._ZNK6String3lenEv 60 0
.xt.prop._ZN6String6setLenEi 60 0
.xt.prop._ZNK6String7wbufferEv 48 0
.xt.prop._ZTISt9exception 12 0
.xt.prop._ZTISt9bad_alloc 12 0
.xt.prop._ZTVN10__cxxabiv117__class_type_infoE 12 0
.xt.lit._ZNK9__gnu_cxx24__concurrence_lock_error4whatEv 8 0
.xt.lit._ZNK9__gnu_cxx26__concurrence_unlock_error4whatEv 8 0
.xt.lit._ZN9__gnu_cxx24__concurrence_lock_errorD5Ev 8 0
.xt.lit._ZN9__gnu_cxx26__concurrence_unlock_errorD5Ev 8 0
.xt.lit._ZN9__gnu_cxx7__mutex4lockEv 8 0
.xt.lit._ZN9__gnu_cxx13__scoped_lockD5Ev 8 0
.xt.prop._ZNK9__gnu_cxx24__concurrence_lock_error4whatEv 48 0
.xt.prop._ZNK9__gnu_cxx26__concurrence_unlock_error4whatEv 48 0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD5Ev 12 0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD5Ev 12 0
.xt.prop._ZN9__gnu_cxx7__mutex4lockEv 60 0
.xt.prop._ZN9__gnu_cxx13__scoped_lockD5Ev 12 0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD2Ev 36 0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD2Ev 36 0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD0Ev 36 0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD0Ev 36 0
.xt.prop._ZN9__gnu_cxx13__scoped_lockD2Ev 72 0
.xt.prop._ZTIN9__gnu_cxx24__concurrence_lock_errorE 12 0
.xt.prop._ZTIN9__gnu_cxx26__concurrence_unlock_errorE 12 0
.xt.prop._ZTVN9__gnu_cxx24__concurrence_lock_errorE 12 0
.xt.prop._ZTVN9__gnu_cxx26__concurrence_unlock_errorE 12 0
.xt.prop._ZTVSt9bad_alloc 12 0
.xt.prop._ZTVN10__cxxabiv120__si_class_type_infoE 12 0
.debug_macro 153843 0
Total 4179887
<lambda>(["upload"], [".pio\build\esp32dev\firmware.bin"])
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esp-prog
openocd -d2 -s C:/Users/jake/.platformio/packages/tool-openocd-esp32/share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg -c "program_esp32 {{.pio\build\esp32dev\firmware.bin}} 0x10000 verify" -c "program_esp32 {{C:/Users/jake/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin}} 0x1000 verify" -c "program_esp32 {{C:/Users/jake/Documents/PlatformIO/Projects/TestFiles/Test_blink/.pio/build/esp32dev/partitions.bin}} 0x8000 verify" -c "program_esp32 {{C:/Users/jake/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin}} 0xe000 verify" -c "reset run; shutdown"
debug_level: 2
none separate
Info : clock speed 10 kHz
Info : Target halted. PRO_CPU: PC=0x400E8252 (active) APP_CPU: PC=0x400E8252
Info : Detected debug stubs @ 3ffc0c4c on core0 of target 'esp32'
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
** Programming Started **
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x40000400
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 44 KB
Info : Flash mapping 1: 0x20018 -> 0x400d0018, 97 KB
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
