In a project I’m working with for a few months now and that has always worked fine. I get an error while trying to debug with a esp-prog through the PIO debugging. The Pre build task is running smoothly. But in the Debug console I get the error " undefinedDer Befehl “platformio” ist entweder falsch geschrieben oder konnte nicht gefunden werden." which would translate to something like “undefined the command “platformio” is either written wrong or could not be found”.
I did not change anything in my build settings. The upload throuth esp-prog works fine. It’s just the debugger having an issue
platformio.ini:
framework = espidf
debug_tool = esp-prog
upload_protocol = esp-prog
launch.json:
// PlatformIO Debugging Solution
// Documentation: https://docs.platformio.org/en/latest/plus/debugging.html
// Configuration: https://docs.platformio.org/en/latest/projectconf/sections/env/options/debug/index.html
"version": "0.2.0",
"configurations": [
"type": "platformio-debug",
"request": "launch",
"name": "PIO Debug",
"executable": "C:/Users/bkellermann/Documents/PlatformIO/Projects/SICO-Hub-IDF/.pio/build/esp32dev/firmware.elf",
"projectEnvName": "esp32dev",
"toolchainBinDir": "C:/Users/bkellermann/.platformio/packages/toolchain-xtensa-esp32/bin",
"internalConsoleOptions": "openOnSessionStart",
"preLaunchTask": {
"type": "PlatformIO",
"task": "Pre-Debug"
"name": "PIO Debug (without uploading)",
"loadMode": "manual"
