Did you check here: Boot Mode Selection - ESP32-C3 - — esptool.py latest documentation
Hi, @ fishbone
Thank you for providing this debugging information, I have the same problem as you, and finally solved them according to your prompts.
By the way, in my case, click the “Downgrade WCID Drive” is wrong:
the right way is click on the downward triangle symbol, and select the “install driver”, then the button changes to “Replace Driver”, click the button, the winusb10.0 changes to winusb6.1.
Best regards.
