Hello everyone
I am working on an ESP32 project and want to debug it with a JLINK EDU. Previously I have worked with STM32 via the SWD and JTAG interface and it has always worked like a charm. I was able to program and debug the STM32s via the JLINK commandline interface but also with PlatformIO.
I work with a Windows 11 PC and have changed the drivers for the JLINK with Zadig to the WinUSB as recommended on the Internet. I suspect that there is a problem with Windows 11 or my drivers, so I hope that someone has already found a solution.
I am trying to load an empty sketch:
void setup()
void loop()
And I use the following settings for it:
debug_tool = jlink
upload_protocol = jlink
When I click on upload I get the following output:
PLATFORM: Espressif 32 (3.5.0) > Espressif ESP32 Dev Module
DEBUG: Current (jlink) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.10006.210326 (1.0.6)
- tool-esptoolpy @ 1.30100.210531 (3.1.0)
- tool-openocd-esp32 @ 2.1000.20210721 (10.0)
- toolchain-xtensa32 @ 2.50200.97 (5.2.0)
Found 28 compatible libraries
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 4.0% (used 13224 bytes from 327680 bytes)
Flash: [== ] 15.4% (used 201216 bytes from 1310720 bytes)
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = jlink
Uploading .pio\build\esp32dev\firmware.bin
Open On-Chip Debugger v0.10.0-esp32-20210721 (2021-07-21-13:35)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 5000 kHz
Warn : Failed to open device: LIBUSB_ERROR_NOT_SUPPORTED.
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: Couldn't halt target before SoC reset
embedded:startup.tcl:449: Error: ** Unable to reset target **
in procedure 'program_esp'
in procedure 'program_error' called at file "C:/Users/geiss/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp_common.cfg", line 93
at file "embedded:startup.tcl", line 449
*** [upload] Error 1
==================================================================================================================================== [FAILED] Took 2.31 seconds ====================================================================================================================================
The terminal process "C:\Users\geiss\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
