Debugging ESP32 S3 using built-in jtag
I’m attempting to use the built-in jtag debugger with a ESP32-S3-DevKitC-1, unfortunately I’m running into a problem. According to this, the issue should be solved, but I’m getting the following error:
Open On-Chip Debugger  v0.11.0-esp32-20220411 (2022-04-11-08:48)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
adapter speed: 40000 kHz
Warn : Transport "jtag" was already selected
DEPRECATED! use 'adapter speed' not 'adapter_khz'
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: esp_usb_jtag: could not find or open device!
Assertion failed!
Program: C:\Users\trabi\.platformio\packages\tool-openocd-esp32\bin\openocd.exe
File: ../src/jtag/core.c, Line 338
Expression: jtag_trst == 0
Remote communication error.  Target disconnected.: Success.
I’m using the platform version 5.0, which, if I’m not mistaken has that fix mentioned above.
Just an update:
The ESP needed to be in the bootloader. For whatever reason the program it came with would not enable jtag (possibly because it was using cdc uart?)
What do you mean by “ESP needed to be in the bootloader”. How did you do this?
Hold boot button, press reset, release boot button? ESP32-S3-DevKitC-1 v1.1 - ESP32-S3 - — ESP-IDF Programming Guide latest documentation
Try this in esp-idf 5.0
change in the file esp32-bidge.cfg
source [find interface/esp_usb_jtag.cfg]
esp_chip_model_t
espusbjtag chip_id 9
