I’m trying to debug my project to get more detail on what is happening with my dynamically stored memory in my project. I’ve setup Clion (latest version) with platformio IO. I installed the core using python and pip install. I can build and upload to the board successfully but when I insert a breakpoint on a line and attempt to run the debugger, I get the error:
Debugger process ended with exit code 1
I have the Arduino framework installed I believe (I have the Arduino IDE, as well as the platformIO installed on VScode && Clion). Do I need additional drivers or any other framework in order to get the debugger working properly? If so, how do I go about installing that?
Here is my platformio.ini.
Note: I happened to figure out the issue with my code without a debugger, however I think it would have certainly been helpful to have that tool at my disposal.
simavr would be fine I would guess, so long as it allows me to step through the program and check variable values and whatever else in memory.
The issue I was having was related to the limited SRAM of the Arduino Uno. I was trying to return a very large String at one time without checking for available memory or periodically flushing the serial buffer .
[env:uno]
board = uno
mike-matera/ArduinoSTL@^1.1.0
https://github.com/mpflaga/Arduino-MemoryFree.git
@maxgerhardt
Hey Max, any update as to why the debugger isn’t launching? I would appreciate any further help with this. Thanks!
Same problem here. What is going on with it?!
Please post a new topic with the exact platformio.ini, code and hardware (microcontroller + debugger) setup that you are working with.
