I know that Particle is doing their own IDE called workbench. I’m curious however, if I can use Platform.io’s debugger to debug code using their new mesh debugger hardware what ties into their mesh boards using SWD.
My question is this if I have an elf file from the result of the compilation using particle workbench.
I have openocd properly configured using their board config file.
Could I then use platformio debugger to attach to that openocd target and with the corresponding elf file do all my debugging in platoforms ide?
