I’m tying to debug on the STM32F469IDiscovery but without any success, i thought that as long as a board is supported this should just work - clearly i am missing something.
I get the following message after a successful compile.
And the following message in the debug-console.
Reading symbols from c:/…/.pioenvs/disco_f469ni/firmware.elf…
done.
PlatformIO Unified Debugger > Redirecting...
GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00392-gbe9ef0b0 (2018-01-12-15:03)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : tcl server disabled
Info : telnet server disabled
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Error: open failed
in procedure ‘init’
in procedure ‘ocd_bouncer’
.pioinit:12: Error in sourced command file:
Remote communication error. Target disconnected.: Success.
Any ideas what might be wrong?
