Hi, a newbie to PIO and ESP32 here. I have a custom WRover board, and a new FT232H, and am having difficulty debugging some programs. For example, espidf-blink will debug, but espidf-aws-iot , or similar programs with IoT and Wifi, time out on the same hardware. .
Environment: Win10, VSCode, PlatformIO, version 4.1.0b1
I followed the instructions in Medium article, The debugger appears to be attached correctly, since it finds the 2 cores, but then times out. The JTAG pins are all dedicated. Not sure where to look next. Ideas:?
1 My module has 16MB of flash, does that matter?
2.Does the debugger need a reset line?
Thanks.
Debugger Log:
PlatformIO: debug_tool = ftdi
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
ftdi samples TDO on falling edge of TCK
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description '*', serial '*' at bus location '*'
Info : clock speed 20000 kHz
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Error: No symbols for FreeRTOS
Info : Target halted. PRO_CPU: PC=0x40007BA1 (active) APP_CPU: PC=0x00000000
Ignoring packet error, continuing...
warning: unrecognized item "timeout" in "qSupported" response
Error: timed out while waiting for target halted / 4 - 2
Info : Target halted. PRO_CPU: PC=0x40090069 (active) APP_CPU: PC=0x00000000
Error: xtensa_wait_algorithm: not halted 0, pc 0x40090069, ps 0x60025
Error: Failed to wait algorithm (-302)!
Error: Algorithm run failed (-302)!
Error: Failed to run flasher stub (-302)!
Warn : Failed to get flash mappings (-302)!
Error: Target is already running an algorithm
Error: Failed to start algorithm (-4)!
Error: Algorithm run failed (-4)!
Error: Failed to run flasher stub (-4)!
Error: Failed to probe flash, size 0 KB
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Error: error during select: Unknown error
Warn : Flash driver of esp32.flash does not support free_driver_priv()
Warn : Flash driver of irom does not support free_driver_priv()
Warn : Flash driver of drom does not support free_driver_priv()
Remote communication error. Target disconnected.: No error.
