On a fresh project created via the CLion, when the Debug button at the top right corner is click a error message “Debugger process finished with exit code 1. Rerun ‘PlatformIO Debug’” is shown.
What’s the platformio.ini?
The default one:
[env:uno]
board = uno
That can’t work. The documentation says the default debug-protocol is avr-stub, which needs more platformio.ini instructions regarding adding the library, specyfing the debug port, etc. Also, it needs special code to initialize the software GDB stub on the device. It also has limitations that need to be considered carefully.
You should also setup the AVR-stub debugger in the CMake toolchain settings (tools are in C:\Users\<user>\.platformio\packages\toolchain-atmelavr@1.70300.191015\bin for me).
Once I do that, it works without problems on real hardware.
That is with
[env:uno]
board = uno
debug_port = \\.\COM33
debug_tool = avr-stub
jdolinay/avr-debugger @ ~1.4
and code
#include "Arduino.h"
#include "avr8-stub.h"
static int i=0;
void setup()
// initialize GDB stub
debug_init();
pinMode(LED_BUILTIN, OUTPUT);
void loop()
i++;
delay(i * 50);
delay(1000);
If you do not want to debug on real hardware, use simavr, as stated in the board’s documentation that I have linked above.
debug_tool = simavr
I have updated the configuration as yours. The debugger starts, but there are two issues.
It doesn’t stop on any breakpoint. The console’s output says that they can’t be found:
Console output: Preparing firmware for debugging...Processing uno (platform: atmelavr; board: - Pastebin.com
Code:
#include “Arduino.h”
#include “avr8-stub.h”
debug_init();
int a = 5;
char k = ‘A’;
The #include of “avr8-stub.h” is marked in red saying that ‘avr8-stub.h’ file not found
The default optimization level -Og prevents any code from being emitted here, hence no breakpoint can be set. You need to add a function call here, e.g. delay(a);, or use different debug_build_flags with -O0.
Weird. Can’t reproduce the problem.
All works nicely.
And that is with
[env:uno]
board = uno
debug_build_flags = -O0 -ggdb3 -g3
You should also do a Tools → PlatformIO → Re-Init so that the red squiggly lines go away (index rebuild).
The problem was in the debug_build_flags.
That will not work: debug_build_flags = -O0
That will work: debug_build_flags = -O0 -ggdb3 -g3
Also thanks for the index rebuild hint.
Looks like that thread is a perfect tutorial for someone like me, who doesn’t know how to setup the debugger and can hit something in the way
