Went to the FTDI website and downloaded the VCP driver.
Mac OS X10.15 and macOS 11/12 2021-05-18 1.4.7 This is a Beta driver release and the installer should be run from the Applications folder on your machine
Ran the installer from the App directory and enabled the extension. Pressed "Install FTDI USB Serial Dext VCP and App says: Succeeded.
When I try to use the driver in the IDE; I get the following from the debug window:
Reading symbols from /Users/donaldhewitt/Documents/PlatformIO/Projects/pir_relay_example/.pio/build/az-delivery-devkit-v4/firmware.elf…
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20210721 (2021-07-21-13:34)
Licensed under GNU GPL v2
For bug reports, read OpenOCD: Bug Reporting
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_claim_interface() failed with LIBUSB_ERROR_ACCESS
Error: unable to open ftdi device with vid 0403, pid 6010, description ‘', serial '’ at bus location ‘’
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6014, description '’, serial ‘’ at bus location '’
Assertion failed: (jtag_trst == 0), function jtag_checks, file …/src/jtag/core.c, line 343.
Remote connection closed
Error Domain=KMErrorDomain Code=71 “Kernel request failed: (libkern/kext) not found (-603947002)” UserInfo={NSLocalizedDescription=Kernel request failed: (libkern/kext) not found (-603947002)}
This also looks like duplicate drivers, this time for the CH340G chip. Again, remove any third-party drivers as MacOS has suitable Apple drivers out-of-the-box. Or leave it alone as /dev/cu.SLAB_USBtoUART is working.
For upload, you now have two options:
useesp_tool through /dev/cu.SLAB_USBtoUART
use JTAG through ESP-Prog. (It’s not actually using /dev/cu.usbserial-14501 as it doesn’t use the serial protocol.)
Test the latter one by configuring it like so:
upload_protocol = esp-prog
If that works, debugging is also very likely to work.
Just to make sure. I need to use the ESP-Prog to upload to the ESP32 and to connect to the JTAG ports? So; I will just have one serial cable from the MBP to the ESP-Prog?
I’m assuming you have an ESP32 development board with a USB connector that serves both to supply power and for serial communication as well as the ESP-Prog adapter.
If you just want to upload firmware, ESP-Prog is not needed. You can directly upload via the serial connection. But if you are preparing the setup for debugging, you have the option to also upload via JTAG (using ESP-Prog). This option is helpful for figuring out if the JTAG interface is working.
If you use ESP-Prog, you still need to provide power via the USB connector to the development board, be it from your MacBook or from some USB power supply.
Got it to work. I used the esp-prog for both upload and jtag. I will play around with setting breakpoints and examining variables next. Quite a hurdle with MacOS.
On MacOS, it’s actually the easiest: no driver installation, no permission configuration, no nothing. You just got off on the wrong foot by installing unnecessary drivers (old Windows habit?).
On Windows, you need to download Zadig and switch the drivers because Windows has a very rigid driver model for USB.
On Linux, you need to modify configuration responsible for managing access rights for USB devices.
