Debugger error: .pioinit:11: Error in sourced command file: COM10: No such file or directory
I get this error when starting the debugger. I’m using the Espressif esp_prog as the debugger interface. I’m also using it as the communications interface since the on-board USB port isn’t working.
Here’s the.ini file:
[env:esp32-c3-devkitm-1]
board = esp32-c3-devkitm-1
lib_extra_dirs = ~/Documents/Arduino/libraries
upload_port = COM11
debug_port = COM10
debug_tool = esp-prog
Error message:
undefinedOpen On-Chip Debugger v0.11.0-esp32-20220411 (2022-04-11-08:48)Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
DEPRECATED! use ‘adapter speed’ not ‘adapter_khz’
adapter speed: 5000 kHz
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description ‘', serial '’ at bus location ‘
Error: unable to open ftdi device with vid 0403, pid 6014, description '
’, serial ‘’ at bus location '
C:\Users\robgo.platformio\packages\toolchain-riscv32-esp\bin\riscv32-esp-elf-gdb.exe: warning: Couldn’t determine a path for the index cache directory.
Reading symbols from c:\Users\robgo\OneDrive\Documents\PlatformIO\Projects\230306-194856-esp32-c3-devkitm-1.pio\build\esp32-c3-devkitm-1\firmware.elf…
PlatformIO: debug_tool = esp-prog
COM10: No such file or directory.
type or paste code here
Libusb drivers installed for the right interface using Zadig?
Thanks for responding. I have the libusb-win32 (v1.2.7.3) driver installed for Dual RS232 +HS (Interface 0). I get the same error message. I’m using a 64-bit Widows desktop.
Weird. Same with WinUSB as selected driver?
Doesn’t matter which driver I use. I get this error in the debugger console:
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Error: unable to open ftdi device with vid 0403, pid 6010, description ‘', serial '’ at bus location ‘*’
The ports look like this.
com ports
COM9 goes straight to the target on-board USB port.
Can you remove that line? Debugging goes via the USB device, not a serial port.
I decided to start fresh and uninstall the USB ports other than COM1 and COM3.
PlatformIO .ini file
; change microcontroller
board_build.mcu = esp32c3
I then connected the esp32-prog to a USB port and Device Manager showed “Dual RS-232-HS (Interface 0) (COM5) & USB Serial Port (COM13)”
I then connected the target board’s (ESP32-C3-DevKit-1) built in USB port and Device Manager showed "Silicon Labs CP210x USB to UART Bridge (COM9).
com ports2
RUN >START DEBUGGING
(End of`Terminal Output:)
Found 31 compatible libraries
Scanning dependencies…
Building in debug mode
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 2.9% (used 9368 bytes from 327680 bytes)
Flash: [= ] 14.8% (used 193366 bytes from 1310720 bytes)
================================================== [SUCCESS] Took 5.31 seconds ==================================================
When I start the debugger I get:
(DEBUG CONSOLE)
undefinedC:\Users\robgo.platformio\packages\toolchain-riscv32-esp\bin\riscv32-esp-elf-gdb.exe: warning: Couldn’t determine a path for the index cache directory.
Reading symbols from c:\Users\robgo\OneDrive\Documents\PlatformIO\Projects\LED TEST.pio\build\esp32dev\firmware.elf…
OpenOCD: Bug Reporting
What am I doing wrong?
Can you show the screenshot for Zadig
Ah that’s a ESP32C3, its JTAG pins might be different to ESP32. Did you check the datasheet?
Can you show a screenshot of Zadig on the two Dual RS232-HS interfaces?
zadig1
zadig2
zadig3
I double checked the JTAG connections and they are correct.
This doesn’t look right at all. Per the article linked above You should WinUSB drivers on Interface 0, and Inteface 1 should have usbser (serial port) drivers installed. Instead you have usbserv on Interface 0 and the native FTDI drivers (FTDIBUS) on Interface 1. Try to use “Replace Driver” as needed in Zadig.
I’ve tried another ESP-PROG board and a different computer and I get the same results.
Here’s the debug console output:
undefinedC:\Users\rxbgx.platformio\packages\toolchain-riscv32-esp\bin\riscv32-esp-elf-gdb.exe: warning: Couldn’t determine a path for the index cache directory.
Reading symbols from C:\Users\robgo\OneDrive\Documents\PlatformIO\Projects\LED TEST.pio\build\esp32dev\firmware.elf…
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Info : clock speed 5000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway…
Error: esp32c3.cpu: IR capture error; saw 0x00 not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: dtmcontrol is 0. Check JTAG connectivity/board power.
Warn : target esp32c3 examination failed
Info : starting gdb server for esp32c3 on pipe
Info : accepting ‘gdb’ connection from pipe
Error: Target not examined yet
Error executing event gdb-attach on target esp32c3:
Warn : No symbols for FreeRTOS!
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use ‘gdb_memory_map disable’.
Error: attempted ‘gdb’ connection rejected
Error: error during select: Unknown error
Remote communication error. Target disconnected.: Success.
Zadig configuration:
This computer is a laptop running Windows 11
Sorry - Last screen shot didn’t show Interface 1
The result of “not working” may be the same but this is fundamentally different to all the last previously shown output. It has now found the adapter and tried to speak to the ESP32C3, but failed to do so.
  1. Add debug_speed = 500 into the platformio.ini to reduce the JTAG clock to a more stable one
  2. Double check that the target is independently powered, aka via a e.g. own USB cable, not via the ESP-PROG
  3. Double check from the ESP32C3 datasheet that you’re connecting the ESP-PROG to the correct JTAG pins. They may differ from the ESP32’s shown in the article above.
Target is powered through it’s own USB connection. I changed the debug speed to 500 and it did go into debug mode briefly before disconnecting. I then tried changing the speed, first to 200, then 100 but it wouldn’t connect. I went back to 500 but still no connection.
adapter speed: 500 kHz
Error: failed to reset FTDI device: LIBUSB_ERROR_PIPE
Error: Unsupported xlen: -1
Error: Unknown target arch!
At this point I’ve tried 3 different ESP-Prog boards, two ESP32-3C-DevkitM-1 boards, multiple USB cables, board-to-board wires and two computers (Windows 10 desktop and a Windows 11 laptop) so it would seem unlikely that its hardware related. The laptop also a fresh install of PlatformIO.
I’ve seen many posts where using OneDrive was a death sentence and weirdly interact with build systems. Though I don’t see a smoking gun as to this being a problem here, better play it safe and move the project to a non-OneDrive folder.
This looks like a regression, it now again fails to find the correct FTDI device: Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND (IDFGH-9317) (OCD-709) · Issue #270 · espressif/openocd-esp32 · GitHub
Double-check in Zadig that the drivers are still as expected.
The ESP-PROG connector is one side, the ESP32C3 is another. You made sure to use the JTAG pins as illustrated in ESP32-C3-DevKitM-1 - ESP32-C3 - — ESP-IDF Programming Guide latest documentation, i.e. GPIO4 to 7?
I have also have C3 dev board and a FTDI adapter, I’ll test tonight whether this works or not.
Sorry - The entire image didn’t show up the first time.
I find it makes a difference when I specifiy the upload_port and debug_port in .ini file.
Here’s a couple of screen shots.
When I specify the debug port it looks like the debugger is running but it really just hangs. If I don’t specify the upload_ port it tries to use COM8. So I spec COM3 as the upload_port and COM7 as the dbug_port.
debug_port should not be specified at all, especially not as a COM port in your case. The debug port is the argument to GDB’s target remote <debug_port> command and automatically correctly points to 127.0.0.1:3333, which is where OpenOCD, if it can connect successfully, will open the GDB server at. The debug port is not a COM port. Even to GDB, the FTDI adapter appears as a libusb device, it does not interact with it as if it were a serial port.
The only cases in which debug_port can be COM port is when there’s a GDB serial stub running on the target device (i.e. the serial port transports the GDB packets directly to a GDB server opened on the target) or for the BlackMagicProbe. Both do not apply here.
