Hi everyone,
The title speaks for itself, I have a custom esp32s3-wroom board that I can easily upload on. But lately I’ve tried to use the platform Io debug option and it doesn’t work.
Please fin my platform.ini file, and the debug error:
I’ve already tried many solution found online but for the moment nothing works,
undefinedC:\Users\n.grauer.platformio\packages\toolchain-xtensa-esp32s3\bin\xtensa-esp32s3-elf-gdb.exe: warning: Couldn’t determine a path for the index cache directory.
Reading symbols from c:\Users\n.grauer\OneDrive - VIMS\Documents\PlatformIO\Projects\MicroC-V0.pio\build\esp32-s3-devkitc-1\firmware.elf…
PlatformIO: debug_tool = esp-builtin
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
Info : only one transport option; autoselect ‘jtag’
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
adapter speed: 40000 kHz
Warn : Transport “jtag” was already selected
adapter speed: 12000 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Error: esp_usb_jtag: could not find or open device!
Remote communication error. Target disconnected.: Success.
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
bblanchon/ArduinoJson@^6.21.4
arkhipenko/TaskScheduler@^3.7.0
throwtheswitch/Unity@^2.5.2
-D _TASK_STATUS_REQUEST
-D _TASK_PRIORITY
-D _TASK_TIMEOUT
-DARDUINO_USB_MODE=1
;-DARDUINO_USB_CDC_ON_BOOT=1
test_build_src = yes
build_type = debug
debug_speed = 12000
