Debug Macro Compilation Errror
I wrote simple program to test debug macros, but it gives me compilation error
//Program:
#define DEBUG
#ifdef DEBUG
  #define DPRINT(...)    Serial.print(__VA_ARGS__)
  #define DPRINTLN(...)  Serial.println(__VA_ARGS__)
#else
  // define blank line
  #define DPRINT(...)
  String str ="Hello MrNams";
  DPRINT("Here is my string %s",str);
Compilation Error:
src/main.cpp: In function 'void setup()':
src/main.cpp:7:50: error: no matching function for call to 'HardwareSerial::print(const char [21], String&)'
src/main.cpp:19:3: note: in expansion of macro 'DPRINT'
In file included from C:/Users/<User Name>/.platformio/packages/framework-arduinoespressif32/cores/esp32/Stream.h:26,
                 from C:/Users/<User Name>/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:177,
                 from src/main.cpp:2:
C:/Users/<User Name>/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.h:81:12: note: candidate: 'size_t Print::print(const __FlashStringHelper*)'
     size_t print(const __FlashStringHelper *);
C:/Users/<User Name>/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.h:81:12: note:   candidate expects 1 argument, 2 provided
C:/Users/<User Name>/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.h:82:12: note: candidate: 'size_t Print::print(const String&)'
     size_t print(const String &);
No.
Serial.print and Serial.println are not variadic functions like printf() is. The function has different overloads for the fundamental datatypes, like const char*, int , float`, etc, that is supposed to be printed, but no format specifiers.
Different Arduino-core implementations might give you the option of Serial.printf() which you can then use.
Just follow the source code for this.
