Hello forum,
I’am new to this forum and I have some problems to debug the TI launchpad MSP-
EXP430FR5969.
I use VScode 1.52.1 with PIO addon. In a 1st step I can download the following
program to Launchpad and it works:
WDTCTL = WDTPW + WDTHOLD;
P1DIR |= 0x01;
volatile long int i;
while (1)
for (i = 0; i < 200000; i++);{
P1OUT ^= 0x01;
Following platformio.ini:
[env:lpmsp430fr5969]
platform = timsp430
board = lpmsp430fr5969
monitor_port = COM9
debug_tool = mspdebug
build_type = debug
debug_init_break = tbreak loop
;upload_protocol = mspdebug
debug_port = COM6
debug_build_flags = -O0 -g3 -ggdb -gdwarf-2
The problem is that I don’t have a debug entry in code - something is missing.
Can someone show me my mistake or missing configuration please?
There is a line “undefinedtilib: device initialization failed” at debug console
but I have currently no idea what is missing or what to copy to what folder.
Thank you in advance, Michael.
Additional to my last post the debug output:
> Executing task in folder MSP-Test: C:\Users\Toshiba\.platformio\penv\Scripts
\pio.exe debug <
Processing lpmsp430fr5969 (platform: timsp430; board: lpmsp430fr5969; framework:
arduino)
CONFIGURATION:
https://docs.platformio.org/page/boards/timsp430/lpmsp430fr5969.html
PLATFORM: TI MSP430 (2.2.0) > TI LaunchPad MSP-EXP430FR5969LP
HARDWARE: MSP430FR5969 8MHz, 2KB RAM, 47KB Flash
DEBUG: Current (mspdebug) On-board (mspdebug)
- framework-energiamsp430 1.10807.190926 (1.8.7)
- toolchain-timsp430 1.40603.190926 (4.6.3)
Found 18 compatible libraries
Building in debug mode
Compiling .pio\build\lpmsp430fr5969\src\main.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\HardwareSerial.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\IPAddress.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\MACAddress.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\Print.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\Stream.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\TimerSerial.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\Tone.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\WInterrupts.c.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\WMath.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\WString.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\atof.c.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\avr\dtostrf.c.o
C:\Users\Toshiba\.platformio\packages\framework-energiamsp430\cores
\msp430\atof.c: In function 'atof':
\msp430\atof.c:71:9: warning: floating constant exceeds range of 'double' [-
Woverflow]
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\itoa.c.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\main.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\new.cpp.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\random.c.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\usci_isr_handler.c.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\wiring.c.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\wiring_analog.c.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\wiring_digital.c.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\wiring_pulse.c.o
Compiling .pio\build\lpmsp430fr5969\FrameworkEnergia\wiring_shift.c.o
Archiving .pio\build\lpmsp430fr5969\libFrameworkEnergia.a
Indexing .pio\build\lpmsp430fr5969\libFrameworkEnergia.a
Linking .pio\build\lpmsp430fr5969\firmware.elf
Building .pio\build\lpmsp430fr5969\firmware.hex
Checking size .pio\build\lpmsp430fr5969\firmware.elf
RAM: [ ] 1.0% (used 20 bytes from 2048 bytes)
Flash: [ ] 1.6% (used 792 bytes from 48128 bytes)
======================================================= [SUCCESS] Took 6.53
seconds =======================================================
Can you post the full output in the debug console, starting at the mspdebug invocation?
Hello maxgerhardt,
here is the complete output:
\pio.exe debug <
arduino)
CONFIGURATION:
Woverflow]
If I press the debug button, the debug console shows:
arduino)
CONFIGURATION:
========================= [SUCCESS] Took 3.22 seconds =========================
MSPDebug version 0.24 - debugging tool for MSP430 MCUs
Copyright (C) 2009-2016 Daniel Beer <dlbeer@gmail.com>
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
----------------- NOTE ------------------
Modified version of mspdebug for Energia
Do not use standalone
Chip info database from MSP430.dll v3.3.1.4 Copyright (C) 2013 TI, Inc.
Using new (SLAC460L+) API
MSP430_GetNumberOfUsbIfs
MSP430_GetNameOfUsbIf
Found FET: COM6
MSP430_Initialize: COM6
FET firmware update is required.
Re-run with --allow-fw-update to perform a firmware update.
Reading symbols from c:\Users\Toshiba\Documents\PlatformIO\Projects\MSP-Test
\.pio\build\lpmsp430fr5969\firmware.elf...
done.
PlatformIO: debug_tool = mspdebug
Hm that’s the same message as from Lpmsp430fr6989 unknow MCU HEader - #34 by glynhudson but I don’t know if that’s the way to go, if the firmware update is run it said it bricked the debugging probe.
I would suggest you open an issue at Issues · platformio/platform-timsp430 · GitHub so that the developers can have a look at that.
