debug error occurs as below:
Info : [esp32.cpu1] Target halted, PC=0x40106110, debug_reason=00000000
Thread
3 "IDLE" received signal SIGTRAP, Trace/breakpoint trap.
[Switching to Thread 1073468240]
Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001
_WindowOverflow8 () at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/freertos/port/xtensa/xtensa_vectors.S:1820
1820 /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/freertos/port/xtensa/xtensa_vectors.S: No such file or directory.
Warn : Warning: Both A8 as well as the physical register it points to (AR8) are dirty and differs in value. Results are undefined!
Info : [esp32.cpu0] Target halted, PC=0x500000AF, debug_reason=00000001
Ara\p_fsci14xsnw-sz espin
Warning:
Cannot insert hardware breakpoint 6:Remote communication error. Target disconnected.: Success..
Command aborted.
build, upload and monitor works.
my platformio.ini is as below:
[env:esp_wrover_kit]
board = esp-wrover-kit
build_type = debug
board_build.partitions = min_littlefs.csv
bodmer/TFT_eSPI@^2.4.79
SPI
FS
SPIFFS
lvgl/lvgl@^8.3.2
Webserver
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
debug_tool = ftdi
what should I do?
