Debug aborts with python error
Hi altogether,
I’m trying to debug a simple sketch (blink) with my new ESP32 S3 board, but unfortunately aborts with a wierd error message from python
piodebuggdb -v -e esp32S3
Open On-Chip Debugger  v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
adapter speed: 40000 kHz
Warn : Transport "jtag" was already selected
adapter speed: 5000 kHz
Info : esp_usb_jtag: serial (24:58:7C:CD:A6:48)
Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
Info : clock speed 5000 kHz
Info : JTAG tap: esp32s3.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: esp32s3.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : starting gdb server for esp32s3.cpu0 on 3333
Could not find platform independent libraries <prefix>
Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
ImportError: No module named site
My platformio.ini looks like that
[env:esp32S3]
; board = esp32-s3-devkitm-1
board = esp32-s3-devkitc-1-n16r8v
upload_port = /dev/ttyACM0
upload_speed=921600
test_port = /dev/ttyACM0
test_speed=921600
monitor_port = /dev/ttyACM0
monitor_speed=921600
debug_port=/dev/ttyACM1
    -D SPEED=921600
    -D RGB_BRIGHTNESS=32
    -D ESP32S3
debug_tool = esp-builtin
debug_init_break = break setup
build_type = debug
I’ve no idea what python is trying to tell me as the module should be present
python3 -m site
sys.path = [
    '/home/hst/source/arduino/samples/Blink',
    '/usr/lib/python36.zip',
    '/usr/lib64/python3.6',
    '/usr/lib64/python3.6/lib-dynload',
    '/home/hst/.local/lib/python3.6/site-packages',
    '/usr/lib64/python3.6/site-packages',
    '/usr/lib64/python3.6/site-packages/PIL',
    '/usr/lib64/python3.6/_import_failed',
    '/usr/lib/python3.6/site-packages',
USER_BASE: '/home/hst/.local' (exists)
USER_SITE: '/home/hst/.local/lib/python3.6/site-packages' (exists)
ENABLE_USER_SITE: True
In the meantime - with having much fun while debugging the debugger :wink: - I think I’ve found the origin of the strange python error. It’s the missing support for python 2.7 on my system.
piodebuggdb spawns to the real debugger - in my case xtensa-esp32s3-elf-gdb - which is dynamically linked to libpython2.7.so.1.0. Unfortunately this python version is not supported in my distribution (openSUSE 15.6). To circumvent the inevitable linkage error I had manually installed libpython2.7.so.1.0 a time ago to solve another problem with this missing lib.
Now I must hope that this already known issue is fixed soon :crossed_fingers:
After some kind of one-man-hackathon, I’ve found a solution or at least a workaround :grin:
Following the instructions from espressif I build my own toolchain:
mkdir ~/esp
cd ~/esp
git clone -b v5.2.2 --recursive https://github.com/espressif/esp-idf.git
cd ~/esp/esp-idf
./install.sh esp32s3
And then I replaced the dysfunctional debugger
cd ~/.platformio/packages/toolchain-xtensa-esp32s3/bin
mv xtensa-esp32s3-elf-gdb xtensa-esp32s3-elf-gdb.orig
cp ~/.espressif/tools/xtensa-esp-elf-gdb/14.2_20240403/xtensa-esp-elf-gdb/bin/xtensa-esp32s3-elf-gdb xtensa-esp32s3-elf-gdb
cp ~/.espressif/tools/xtensa-esp-elf-gdb/14.2_20240403/xtensa-esp-elf-gdb/bin/xtensa-esp-elf-gdb-no-python .
cp ~/.espressif/tools/xtensa-esp-elf-gdb/14.2_20240403/xtensa-esp-elf-gdb/lib/xtensa_esp32s3.so ../lib
(the 2 additional files are necessary) - et voilà
Same solution works for an ESP32 (with some minor changes in naming :wink:)
  1. ./install.sh esp32
  2. cd .platformio/packages/toolchain-xtensa-esp32/bin/
  3. mv xtensa-esp32-elf-gdb xtensa-esp32-elf-gdb.orig
  4. cp ~/.espressif/tools/xtensa-esp-elf-gdb/14.2_20240403/xtensa-esp-elf-gdb/bin/xtensa-esp32-elf-gdb .
  5. cp ~/.espressif/tools/xtensa-esp-elf-gdb/14.2_20240403/xtensa-esp-elf-gdb/bin/xtensa-esp-elf-gdb-no-python .
  6. cp ~/.espressif/tools/xtensa-esp-elf-gdb/14.2_20240403/xtensa-esp-elf-gdb/lib/xtensa_esp32.so …/lib/
Had debug console throwing following error when trying to start debug session with ESP-PROG and NodeMCU-32S :
error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
I followed your instructions and now debugging works like a charm. I’m running Ubuntu 24.04
thanks! this fixed my dilemma
