Hi there!
I’m creating a library that tries to connect to WiFi with saved credentials, and if it fails, it starts the ESP32 in WiFi AP mode and starts a webserver. I want to be able to serve static files from that webserver using LittleFS, FatFS or SPIFFS (not sure which one is the best). The thing is that these files will be in the data
folder of the library, not in the main project.
How can I make sure the main project incorporates the data
folder of the library I’m using?
File structure:
main project
src/main.cpp
platformio.ini
platformio.ini
[env]
board = wemos_d1_mini32
lib_extra_dirs =
/home/EngineerDaryl/lib/
wifimanager
/home/EngineerDaryl/lib/wifimanager
include/wifimanager.h
src/wifimanager.cpp
data/index.html
library.json
When I click on Upload Filesystem Image in the main project, it tries to create a File System using the data folder in the main project, that doesn’t exist. I want it to upload the data in the library folder, without me having to specify it. I’m planning on using this library for more projects.
Hope I made my issue clear enough.
Daryl
