I get the following error when trying to compile the library:
[Mon Sep 21 18:13:27 2020] Processing uno (platform: atmelavr, lib_install: 54,116,252, board: uno, framework: arduino)
LibraryManager: Installing id=54
DallasTemperature @ 3.9.1 has been successfully installed!
Warning! Library `{'version': u'^2.3.5', 'name': u'paulstoffregen/OneWire'}` has not been found in PlatformIO Registry.
You can ignore this message, if `{'version': u'^2.3.5', 'name': u'paulstoffregen/OneWire'}` is a built-in library (included in framework, SDK). E.g., SPI, Wire, etc.
LibraryManager: Installing id=252
JeeLib @ 0.0.0-alpha+sha.635113edea has been successfully installed!
Converting Shield_CT1234_Voltage_SerialOnly.ino
Collected 28 compatible libraries
Looking for dependencies...
Error: Could not find `paulstoffregen/OneWire` dependency for `DallasTemperature` library
I examined the current library.json file v3.9.1 with the previous v3.9.0 and the dependency syntax is completely different ie:
V3.9.1:
"dependencies":
"paulstoffregen/OneWire": "^2.3.5"
V3.9.0:
"dependencies":
"name": "OneWire",
"authors": "Paul Stoffregen",
"frameworks": "arduino"
But I am a complete beginner and dont know how to get platformio to use the previous version.
